NumPy Snippets # 6 .... much ado about nothing ... NaN stuff
2353
09-09-2016 08:45 AM
DanPatterson_Retired
1 0 2,353
NumPy Snippets
Updated: 2016-09-09
Recently I posted about 'nothing' in None isn't...nor is 0 or 1 ... more explorations into geometry  .
This snippet shows how to deal with nothing... errrr ... nulls.  Simply put, for most numpy functions, there is an option to account for numeric null values... NaN ... in python parlance.  Now remember, ArcMap often has to deal with null values in fields.  This is often a stumbling block for people trying to summarize their data.  Here is the snippet for you to think about then to explore.
numpy_NaN
Author:  [email protected]
Purpose:
Create an array using a 'seed' list, caste it as a float and then
do some sums with sums with and without a mask
import numpy as np
fields = ['a','b','c','d','e']        # field names used to define columns
seed = [['1','2','3','4','5'],
        ['2','3','4','5','1'],
        ['2','3','4','5','2']]
a = np.asarray(seed,dtype='float64')  # produce the array
b = np.sum(a,axis=0)                  # sum by the columns
print("\nSum Demo... \nUsing np.sum(array,axis=0)\nUsing np.nansum(array,axis=0)")
print('\nData:\n{}\n\nColumn sum no nulls:\n{}'.format(a,b))
# now with nulls
null = np.NaN                         # NaN... not a number ... or is it?
seed2 = [['1',null,'3','4','5'],
         [null,'3','4','5','1'],
         [null,'3',null,'5','2']]
a2 = np.asarray(seed2,dtype='float64')
b2 = np.sum(a2,axis=0)
c2 = np.nansum(a2,axis=0)
print('\nData with nulls... :\n{}\n\nColumn sum with nulls:\n{}'.format(a2,b2))
print('\nColumn sum omitting nulls:\n{}'.format(c2))
Now...the reveal...
Sum Demo...
Data:
[[ 1.  2.  3.  4.  5.]
[ 2.  3.  4.  5.  1.]
[ 2.  3.  4.  5.  2.]]
[[  1.  nan   3.   4.   5.]
[ nan   3.   4.   5.   1.]
[ nan   3.  nan   5.   2.]]
Column sum no nulls:            [  5.   8.  11.  14.   8.]
Column sum with nulls:         [ nan  nan  nan  14.   8.]
Column sum omitting nulls:   [  1.   6.   7.  14.   8.]
So clever isn't it.. now there are other np.nan... functions to explore.
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
