Multiple Field Key to Single Field Key Tool - Relate Two Layers Based on More than One Field
9677
6
06-07-2015 12:10 PM
RichardFairhurst
5 6 9,677
I have created a Python toolbox tool that converts the set of unique key values found in multiple fields that relate two layers/tables into a set of related sequential numbers in a CASE_ID field populated in both layers/tables.  This allows a user to create a standard join or relate between the two layers/tables on the CASE_ID field that is equivalent to creating a multi-field join or relate.
This tool was inspired by the ArcInfo Workstation's FREQUENCY command which could optionally add a numeric case field to the source and output that would maintain a single field relationship when the frequency was based on more than one case field.  That capability was lost in the Desktop Frequency tool.  However, the tool I have created is actually more flexible than what Workstation provided, since it can be applied to any pair of layers/tables, even when the Frequency tool had nothing to do with how they were created or related.
The two zipped python toolboxes attached are designed for ArcGIS 10.3 (Field Match Tools.pyt.zip) and ArcGIS 10.2 (Field Match Tools v10.2.pyt.zip) .  The toolboxes should be placed in the "%APPDATA%\ESRI\Desktop10.[3]\ArcToolbox\My Toolboxes" folder to show up in your My Toolbox under ArcCatalog (modify the items in brackets to fit your Desktop version).
I use python lists and itertools to get my sorted unique list of multiple field key values and to generate the sequential numbers associated with each key, but I convert the list into a dictionary prior to running the updateCursor so that I gain the speed or dictionary random access matching when I am writing the Case ID number values back to the data sources.  Dictionary key matching is much faster than trying to locate matching items in a list.  Here is the interface:
The validation works to make sure that the two input data sources are not the same and that the fields used in the case field list are actually in both sources.  The user can choose as many fields as they want to make up their unique multiple field case value keys.  The field names do not have to be the same in both data sources.  The position of the fields in the list will control the sort priority of the Case Fields (highest priority = top field) and the Sort Order column controls whether the values in each field are sorted in Ascending or Descending order.  The sort order of the Case field values controls the Case ID number sequencing.  The arrangement of the fields can be different from the field arrangement actually used in the sources.
There are three options for creating sequential numbers in the CASE_ID field output.  The first operates like a standard Join, where all unique key values in the Primary table are numbered, but only matching key values in the Secondary table are numbered.  All unmatched values in the Secondary table are given a CASE_ID of -1.  The second option is an union, where the sequential numbers are based on the complete set of key values in the combination of the Primary and Secondary layers/tables.  The third option is an intersection, where only key values found in both layers/tables receive positive sequential numbers.  All unmatched values of either table not found in the other table received a CASE_ID of -1.
The 10.3 version tool works the best and has the best features, However, I have provided a 10.2 version, but in order for the tool to work under the limitations of 10.2, the tool has fewer capabilities and a somewhat less intuitive interface.  The 10.2 version of the tool does not support controlling the sort order of the fields, so their sequential number values are always based on the use of an ascending order for the field values.  To match the fields in the two layers/tables you must click on fields in two lists, but those fields only appear in the separate field string text box when you click somewhere outside of the field lists.  The tool sidebar help provides more detail on how to use it.
Here is my code for the 10.3 version of the tool:
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Field Match Tools"
        self.alias = "FieldMatchTools"
        # List of tool classes associated with this toolbox
        self.tools = [MultiToSingleFieldKey, InsertSelectedFeaturesOrRows]
class MultiToSingleFieldKey(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Multiple Field Key To Single Field Key"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # First parameter
        param0 = arcpy.Parameter(
            displayName="Input Primary Table",
            name="in_prim_table",
            datatype="DETable",
            parameterType="Required",
            direction="Input")
        # Second parameter
        param1 = arcpy.Parameter(
            displayName="Input Secondary Table",
            name="in_sec_table",
            datatype="DETable",
            direction="Input")
        # Third parameter
        param2 = arcpy.Parameter(
            displayName="Case Fields",
            name="case_fields",
            datatype="GPValueTable",
            direction="Input")
        param2.columns = [['GPString', 'Primary Case Field'], ['GPString', 'Secondary Case Field'], ['GPString', 'Sort Order']]
        param2.filters[0].type="ValueList"
        param2.filters[0].list = ["X"]
        param2.filters[1].type="ValueList"
        param2.filters[1].list=["x"]
        param2.filters[2].type="ValueList"
        param2.filters[2].list=["Ascending", "Descending"]
        param2.parameterDependencies = [param0.name]
        # Fourth parameter
        param3 = arcpy.Parameter(
            displayName="Case ID Field Name",
            name="in_Case_ID_field",
            datatype="GPString",
            direction="Input")
        param3.value = "CASE_ID"
        # Fifth parameter
        param4 = arcpy.Parameter(
            displayName="The created unique Case ID numbers form this Primary/Secondary relationship:",
            name="case_key_combo_type",
            direction="Input")
        param4.filter.type = "valueList"
        param4.filter.list = ["Left Join","Full Join","Inner Join"]
        param4.value = "Left Join"
        newField = arcpy.Field()
        newField.name = param3.value
        newField.type = "LONG"
        newField.precision = 10
        newField.aliasName = param3.value
        newField.isNullable = "NULLABLE"
        # Sixth parameter
        param5 = arcpy.Parameter(
            displayName="Output Primary Table",
            name="out_prim_table",
            datatype="DETable",
            parameterType="Derived",
            direction="Output")
        param5.parameterDependencies = [param0.name]
        param5.schema.clone = True
        param5.schema.additionalFields = [newField]
        # Seventh parameter
        param6 = arcpy.Parameter(
            displayName="Output Secondary Table",
            name="out_sec_table",
            datatype="DETable",
            direction="Output")
        param6.parameterDependencies = [param1.name]
        param6.schema.clone = True
        param6.schema.additionalFields = [newField]
        # Eighth parameter
        param7 = arcpy.Parameter(
            displayName="String comparisons are Case:",
            name="case_sensitive_combo_type",
            direction="Input")
        param7.filter.type = "valueList"
        param7.filter.list = ["Insensitive","Sensitive"]
        param7.value = "Insensitive"
        # Ninth parameter
        param8 = arcpy.Parameter(
            displayName="String ends trimmed of whitespace:",
            name="whitespace_combo_type",
            direction="Input")
        param8.filter.type = "valueList"
        param8.filter.list = ["Both", "Left", "Right", "None"]
        param8.value = "Both"
        params = [param0, param1, param2, param3, param4, param5, param6, param7, param8]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        if parameters[0].value:
            # Return primary table
            tbl = parameters[0].value
            desc = arcpy.Describe(tbl)
            fields = desc.fields
            l=[]
            for f in fields:
                if f.type in ["String", "Text", "Short", "Long", "Float", "Single", "Double", "Integer","OID", "GUID"]:
                    l.append(f.name)
            parameters[2].filters[0].list = l
        if parameters[1].value:
            # Return secondary table
            tbl = parameters[1].value
            l=[]
            for f in fields:
                    l.append(f.name)
            parameters[2].filters[1].list = l
        if parameters[2].value != None:
            mylist = parameters[2].value
            for i, e in list(enumerate(mylist)):
                if mylist[i][2] != "Descending":
                    mylist[i][2] = "Ascending"
            parameters[2].value = mylist
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        if parameters[3].value and parameters[0].value and parameters[1].value:
            desc = arcpy.Describe(parameters[0].value)
            in_primary = False
            is_primary_error = False
            is_primary_uneditable = False
            for f in fields:
                if parameters[3].value.upper() == f.name.upper():
                    in_primary = True
                    if f.type != "Integer":
                        is_primary_error = True
                    elif not f.editable:
            desc2 = arcpy.Describe(parameters[1].value)
            fields2 = desc2.fields
            in_secondary = False
            is_secondary_error = False
            is_secondary_uneditable = False
            for f2 in fields2:
                if parameters[3].value.upper() == f2.name.upper():
                    in_secondary = True
                    if f2.type != "Integer":
                        is_secondary_error = True
                    elif not f2.editable:
            newField.name = parameters[3].value
            newField.aliasName = parameters[3].value
            fields1 = []
            fields2 = []
            order = []
            for item in parameters[2].value:
                fields1.append(item[0].upper())
                fields2.append(item[1].upper())
                order.append(item[2])
            if str(parameters[0].value).upper() == str(parameters[1].value).upper():
                parameters[1].setErrorMessage("The Input Secondary Table {0} cannot be the same as the Input Primary Table {1} ".format(parameters[1].value, parameters[0].value))
            else:
                parameters[1].clearMessage()
            if in_primary and in_secondary:
                if is_primary_error and is_secondary_error:
                    parameters[3].setErrorMessage("{0} exists and is not a Long Integer field in both the Input Primary and Secondary Tables".format(parameters[3].value.upper()))
                elif is_primary_error:
                    parameters[3].setErrorMessage("{0} exists and is not a Long Integer field in the Input Primary Table".format(parameters[3].value.upper()))
                elif is_secondary_error:
                    parameters[3].setErrorMessage("{0} exists and is not a Long Integer field in the Input Secondary Table".format(parameters[3].value.upper()))
                elif parameters[3].value.upper() in fields1 and parameters[3].value.upper() in fields2:
                    parameters[3].setErrorMessage("{0} is used as a Case Field for both the Input Primary and Secondary Tables".format(parameters[3].value.upper()))
                elif parameters[3].value.upper() in fields1:
                    parameters[3].setErrorMessage("{0} is used as a Case Field for the Input Primary Table".format(parameters[3].value.upper()))
                elif parameters[3].value.upper() in fields2:
                    parameters[3].setErrorMessage("{0} is used as a Case Field for the Input Secondary Table".format(parameters[3].value.upper()))
                elif is_primary_uneditable and is_secondary_uneditable:
                    parameters[3].setErrorMessage("{0} exists and is not editable in both the Input Primary and Secondary Tables".format(parameters[3].value.upper()))
                elif is_primary_uneditable:
                    parameters[3].setErrorMessage("{0} exists and is not editable in the Input Primary Table".format(parameters[3].value.upper()))
                elif is_secondary_uneditable:
                    parameters[3].setErrorMessage("{0} exists and is not editable in the Input Secondary Table".format(parameters[3].value.upper()))
                else:
                    parameters[3].setWarningMessage("{0} will be overwritten in both the Input Primary and Secondary Tables".format(parameters[3].value.upper()))
            elif in_primary:
                parameters[6].schema.additionalFields = [newField]
                else:
                    parameters[3].setWarningMessage("{0} will be overwritten in the Input Primary Table".format(parameters[3].value.upper()))
            elif in_secondary:
                parameters[5].schema.additionalFields = [newField]
                else:
                    parameters[3].setWarningMessage("{0} will be overwritten in the Input Secondary Table".format(parameters[3].value.upper()))
            else:
                parameters[3].clearMessage()
        return
    def stringCaseTrim(self, parameters, value):
        tempstr = None
        if parameters[7].value.upper() == 'Sensitive'.upper():
            tempstr = value
        else:
            tempstr = value.upper()
        if parameters[8].value.upper() == 'None'.upper():
            return tempstr
        if parameters[8].value.upper() == 'Left'.upper():
            return tempstr.lstrip()
        if parameters[8].value.upper() == 'Right'.upper():
            return tempstr.rstrip()
        else:
            return tempstr.strip()
    def execute(self, parameters, messages):
        """The source code of the tool."""
        try:
            in_primary = False
            for f in fields:
                    in_primary = True
            if not in_primary:
                arcpy.AddField_management(parameters[0].value, parameters[3].value.upper(), "Long", 10)
                arcpy.AddMessage("Added a Case ID field to the Input Primary Table")
            for f2 in fields2:
                    in_secondary = True
            if not in_secondary:
                arcpy.AddField_management(parameters[1].value, parameters[3].value.upper(), "Long", 10)
                arcpy.AddMessage("Added a Case ID field to the Input Secondary Table")
            tbl1 = parameters[0].value
            tbl2 = parameters[1].value
            fields1 = []
            fields2 = []
            order = []
               fields1.append(item[0])
               fields2.append(item[1])
            arcpy.AddMessage("Primary Case Fields are {0}".format(str(fields1)))
            arcpy.AddMessage("Secondary Case Fields are {0}".format(str(fields2)))
            arcpy.AddMessage("Sort Orders are {0}".format(str(order)))
            import itertools
            k = []
            arcpy.AddMessage("Strings Comparisons Are {0}".format(parameters[7].value))
            k = list(tuple([self.stringCaseTrim(parameters, value) if str(type(value)) in ("<class 'str'>", "<type 'unicode'>") else value for value in r]) for r in arcpy.da.SearchCursor(tbl1, fields1))
            arcpy.AddMessage("Case Values have been read from the Input Primary Table")
            if parameters[4].value == "Full Join":
                j = []
                j = list(tuple([self.stringCaseTrim(parameters, value) if str(type(value)) in ("<class 'str'>", "<type 'unicode'>") else value for value in r]) for r in arcpy.da.SearchCursor(tbl2, fields2))
                k = k + j
                j = None
                arcpy.AddMessage("Case Values have been appended from the Input Secondary Table")
            from operator import itemgetter
            for i, e in reversed(list(enumerate(order))):
                if order[i] == "Descending":
                    k.sort(key=itemgetter(i), reverse=True)
                else:
                    k.sort(key=itemgetter(i))
            k = list(k for k,_ in itertools.groupby(k))
            if parameters[4].value == "Inner Join":
                arcpy.AddMessage("Case Values have been read from the Input Secondary Table")
                l = []
                for item in k:
                    if tuple(item) in j:
                        l.append(item)
                j = None
                k = l
                l = None
                arcpy.AddMessage("Case Values have been matched to the Input Secondary Table")
            arcpy.AddMessage("A list of sorted and unique Case Values has been created")
            dict = {}
            fields1.append(parameters[3].value)
            fields2.append(parameters[3].value)
            for i in xrange(len(k)):
                dict[tuple(k[i])] = i + 1
            k = None
            arcpy.AddMessage("A dictionary of unique Case Value keys with Case ID number values has been created")
            with arcpy.da.UpdateCursor(tbl1, fields1) as cursor:
                for row in cursor:
                    caseinsensitive = tuple([self.stringCaseTrim(parameters, value) if str(type(value)) in ("<class 'str'>", "<type 'unicode'>") else value for value in row[0:len(fields2)-1]])
                    if caseinsensitive in dict:
                        row[len(fields1)-1] = dict[caseinsensitive]
                    else:
                        row[len(fields2)-1] = -1
                    cursor.updateRow(row)
            del cursor
            arcpy.AddMessage("{0} values have been updated for Input Primary Table".format(parameters[3].value))
            with arcpy.da.UpdateCursor(tbl2, fields2) as cursor2:
                for row2 in cursor2:
                    caseinsensitive = tuple([self.stringCaseTrim(parameters, value) if str(type(value)) in ("<class 'str'>", "<type 'unicode'>") else value for value in row2[0:len(fields2)-1]])
                        row2[len(fields2)-1] = dict[caseinsensitive]
                    else:
                        row2[len(fields2)-1] = -1
                    cursor2.updateRow(row2)
            del cursor2
            arcpy.AddMessage("{0} values have been updated for Input Secondary Table".format(parameters[3].value))
        except Exception as e:
            messages.addErrorMessage(e.message)
        return
class InsertSelectedFeaturesOrRows(object):
    def __init__(self):
        self.label = "Insert Selected Features or Rows"
        # First parameter
            displayName="Source Layer or Table View",
            name="source_layer_or_table_view",
            datatype="GPTableView",
            direction="Input")
        # Second parameter
            displayName="Target Layer or Table View",
            name="target_layer_or_table_view",
            direction="Input")
        # Third parameter
            displayName="Number of Copies to Insert",
            name="number_of_copies_to_insert",
            datatype="GPLong",
            direction="Input")
        param2.value = 1
        # Fourth parameter
            displayName="Derived Layer or Table View",
            name="derived_table",
            direction="Output")
        param3.parameterDependencies = [param1.name]
        param3.schema.clone = True
        params = [param0, param1, param2, param3]
        return params
        return True
        return
            insertFC = parameters[1].value
            strInsertFC = str(insertFC)
            if parameters[0].value and '<geoprocessing Layer object' in strInsertFC:
                FC = parameters[0].value
                strFC = str(FC)
                if not '<geoprocessing Layer object' in strFC:
                    print("Input FC must be a layer if output is a layer")
                    parameters[0].setErrorMessage("Input must be a feature layer if the Output is a feature layer!")
                else:
                    dscFCLyr = arcpy.Describe(FC)
                    dscinsertFCLyr = arcpy.Describe(insertFC)
                    # add the SHAPE@ field if the shapetypes match
                    if dscFCLyr.featureclass.shapetype != dscinsertFCLyr.featureclass.shapetype:
                        print("Input and Output have different geometry types!  Geometry must match!")
                        parameters[0].setErrorMessage("Input and Output do not have the same geometry")
                    if dscFCLyr.featureclass.spatialReference.name != dscinsertFCLyr.featureclass.spatialReference.name:
                        print("Input and Output have different Spatial References!  Spatial References must match!")
                        parameters[0].setErrorMessage("Input and Output do not have the same Spatial References!  Spatial References must match!")
        if parameters[2].value <= 0:
            parameters[2].setErrorMessage("The Number of Row Copies must be 1 or greater")
        return
        try:
            mxd = arcpy.mapping.MapDocument(r"CURRENT")
            df = arcpy.mapping.ListDataFrames(mxd)[0]
            strFC = str(FC)
            FCLyr = None
            insertFCLyr = None
            for lyr in arcpy.mapping.ListLayers(mxd, "", df):
                # Try to match to Layer
                if '<geoprocessing Layer object' in strFC:
                    if lyr.name.upper() == FC.name.upper():
                        FCLyr = lyr
                if '<geoprocessing Layer object' in strInsertFC:
                    if lyr.name.upper() == insertFC.name.upper():
                        insertFCLyr = lyr
            if FCLyr == None or insertFCLyr == None:
                # Try to match to table if no layer found
                if FCLyr == None:
                    tables = arcpy.mapping.ListTableViews(mxd, "", df)
                    for table in tables:
                        if table.name.upper() == strFC.upper():
                            FCLyr = table
                            break
                if insertFCLyr == None:
                        if table.name.upper() == strInsertFC.upper():
                            insertFCLyr = table
                            break
            # If both layers/tables are found then process fields and insert cursor
            if FCLyr != None and insertFCLyr != None:
                dsc = arcpy.Describe(FCLyr)
                selection_set = dsc.FIDSet
                # only process layers/tables if there is a selection in the FCLyr
                if len(selection_set) > 0:
                    print("{} has {} {}{} selected".format(FCLyr.name, len(selection_set.split(';')), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's'))
                    arcpy.AddMessage("{} has {} {}{} selected".format(FCLyr.name, len(selection_set.split(';')), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's'))
                    FCfields = arcpy.ListFields(FCLyr)
                    insertFCfields = arcpy.ListFields(insertFCLyr)
                    # Create a field list of fields you want to manipulate and not just copy
                    # All of these fields must be in the insertFC
                    manualFields =  []
                    matchedFields = []
                    for manualField in manualFields:
                        matchedFields.append(manualField.upper())
                    for FCfield in FCfields:
                        for insertFCfield in insertFCfields:
                            if (FCfield.name.upper() == insertFCfield.name.upper() and
                                FCfield.type == insertFCfield.type and
                                FCfield.type <> 'Geometry' and
                                insertFCfield.editable == True and
                                not (FCfield.name.upper() in matchedFields)):
                                matchedFields.append(FCfield.name)
                                break
                            elif (FCfield.type == 'Geometry' and
                                  FCfield.type == insertFCfield.type):
                                matchedFields.append("SHAPE@")
                                break
                            elif insertFCfield.type == "OID":
                                oid_name = insertFCfield.name
                    if len(matchedFields) > 0:
                        # Print the matched fields list
                        print("The matched fields are: {}".format(matchedFields))
                        arcpy.AddMessage("The matched fields are: {}".format(matchedFields))
                        copies = parameters[2].value
                        print("Making {} {} of each {}".format(copies, 'copy' if copies == 1 else 'copies', 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row'))
                        arcpy.AddMessage("Making {} {} of each {}".format(copies, 'copy' if copies == 1 else 'copies', 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row'))
                        oid_list = []
                        # arcpy.AddMessage(oid_name)
                        dscInsert = arcpy.Describe(insertFCLyr)
                            oid_name = arcpy.AddFieldDelimiters(dscInsert.dataElement, oid_name)
                        else:
                            oid_name = arcpy.AddFieldDelimiters(dscInsert, oid_name)
                        rowInserter = arcpy.da.InsertCursor(insertFCLyr, matchedFields)
                        print("The output workspace is {}".format(insertFCLyr.workspacePath))
                        arcpy.AddMessage("The output workspace is {}".format(insertFCLyr.workspacePath))
                            versioned = dscInsert.featureclass.isVersioned
                        else:
                            versioned = dscInsert.table.isVersioned
                        if versioned:
                            print("The output workspace is versioned")
                            arcpy.AddMessage("The output workspace is versioned")
                            with arcpy.da.Editor(insertFCLyr.workspacePath) as edit:
                                with arcpy.da.SearchCursor(FCLyr, matchedFields) as rows:
                                    for row in rows:
                                        for i in range(copies):
                                            oid_list.append(rowInserter.insertRow(row))
                        else:
                            print("The output workspace is not versioned")
                            arcpy.AddMessage("The output workspace is not versioned")
                                for row in rows:
                        del row
                        del rows
                        del rowInserter
                        if len(oid_list) == 1:
                            whereclause = oid_name + ' = ' + str(oid_list[0])
                        elif len(oid_list) > 1:
                            whereclause = oid_name + ' IN (' + ','.join(map(str, oid_list)) + ')'
                        if len(oid_list) > 0:
                            # arcpy.AddMessage(whereclause)
                            # Switch feature selection
                            arcpy.SelectLayerByAttribute_management(FCLyr, "CLEAR_SELECTION", "")
                            arcpy.SelectLayerByAttribute_management(insertFCLyr, "NEW_SELECTION", whereclause)
                            print("Successfully inserted {} {}{} into {}".format(len(oid_list), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's', insertFCLyr.name))
                            arcpy.AddMessage("Successfully inserted {} {}{} into {}".format(len(oid_list), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's', insertFCLyr.name))
                    else:
                        print("Input and Output have no matching fields")
                        arcpy.AddMessage("Input and Output have no matching fields")
                else:
                    print("There are no features selected")
                    arcpy.AddMessage("There are no features selected")
            # report if a layer/table cannot be found
            if FCLyr == None:
                print("There is no layer or table named '{}' in the map".format(FC))
                arcpy.AddMessage("There is no layer or table named '" + FC + "'")
                print("There is no layer or table named '{}' in the map".format(insertFC))
                arcpy.AddMessage("There is no layer or table named '{}' in the map".format(insertFC))
            arcpy.RefreshActiveView()
            return
            # If an error occurred, print line number and error message
            import traceback, sys
            tb = sys.exc_info()[2]
            print("Line %i" % tb.tb_lineno)
            arcpy.AddMessage("Line %i" % tb.tb_lineno)
            print(e.message)
            arcpy.AddMessage(e.message)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
6 Comments
RichardFairhurst
I have created an improved version of my tool for ArcMap 10.3 (Field Match Tools.pyt.zip).  It now has options that allow string field matches to be case sensitive or case insensitive and that will trim whitespace from strings on Both ends, the Left end, the Right end or None of the ends.  The names of the options controlling the type of relationship the single key field values will represent have been shortened to make the tool easier to use in Python scripts.  I have also included my tool for appending selected records from one layer or table view to itself or another.
I have only updated the ArcMap 10.3 version of the tool, because that tool interface is much easier to use and I have only been using ArcMap 10.3 for the last several years.
RichardFairhurst
During the past 6 months I have used the Multi-Field key to Single-Field Key tool to solve all kinds of problems that previously could not be resolved by ArcMap.  For example, I have used it to detect variant components in a set of 8 fields that make up a contact name and address.  I have managed to eliminate approximately 500K unique address variants which consolidated 2.3 million unique contact records to 1.8 million, and by continuing to use this tool I expect to eliminate over 100K more before my conversion Go Live date. The tool did case insensitive matching directly between fields with different capitalization formats without any need to standardize to a single capitalization format.  It also matched sets of values that included Null values in some or all of the fields, so that in effect Null was treated as a real value that can be matched, which has always been a problem for me with standard joins.
This tool is far better than the Make Query Table tool, because, unlike the Make Query Table tool, my tool does not impose any restrictions on editing, calculating, and refreshing of the data whether it is joined or not and my tool supports all join types, not just an inner join like the Make Query Table tool.  My tool also performs much, much better than the Make Query Table tool on large data sets.  I also frequently find myself using this tool rather than a standard join and select by attribute query on indexed fields across the join, because my tool performs 20 times better and saves me literally hours of wait time.
I believe this tool should be part of the core ArcMap toolbox (with improvements by Esri to make it fully conform to all of their tool standards, of course).  I strongly encourage you to try this tool if you deal with any composite field relationships between your feature classes and tables that you would like to behave like a standard single field relationship.  And I would appreciate your feedback.
RandyBurton
Richard, I didn't see the tool sidebar help in the 10.3 version.  But the version for 10.2 includes help.
RichardFairhurst
Randy:
I have uploaded the Python Toolbox for the 10.3 version again with the xml file, which I believe contains the sidebar help.  I see the sidebar help when I open this tool on my desktop.  Let me know if the new file fixes the problem.
RandyBurton
I believe there should be a total of 3 xml files.  "Field Match Tools.InsertSelectedFeaturesOrRows.pyt.xml" and "Field Match Tools.MultiToSingleFieldKey.pyt.xml" should also be included.  The toolbox wants to create these files if they do not exist.
RichardFairhurst
Randy:
You were right that I needed to include at least two additional xml files.  I have replaced the upload of the tool again and included all of the xml files with the "Field Match Tools" file prefix.  That should take care of the problem.  Thanks for letting me know.
Labels
