Mixing environments for working with python
692
02-04-2026 04:13 PM
DanPatterson
MVP Esteemed Contributor
2 1 692
Ramble
I have a separate miniconda environment nicely set up with the versions of what I want without constraints of what is "pinned" by the arcgispro-py3 environment or its clone.
Sure, you can clone, or make a stripped down environment by using arcpy-base, or if you have that streak of adventure, you can push "pip" ing and such.  Sadly many of those options dont work for me, since I tend to do my "Arc..." stuff separate from my "NumPy ... " stuff.  So here is a demo of what you can do if you only need a simple or quick access to python code that you have and you don't want to mess with the existing Arcgis Pro setup
Working with packages
This is a demo to show how to use your own modules within the arcgis pro environment. The modules that you need to import have to be identified, then imported.
  1. Identify the location for the package/module/script you want to import
  2. Do any required imports.
Once you have done your imports, your package/module/script can be used within ArcGIS Pro's notebooks, python windows and tools.
packages_02.pngpackages_02.pngUsing the python window do a simple import and get a list of the folders that Pro searches looking for python packages etcetera.
In my example, I installed Arcgis Pro on my machine locally in C:\Arcpro_36.
Now, I wanted to add paths to the location where I save my packages.  The simple script to the right shows one way.
packages_05.pngpackages_05.pngYou can also continue working there in either a notebook or the python window.  In the example to the right, the project, active map and a layer list was obtained.
Now, I imported my own module to convert it to a numpy array, obtain some information and produce a "map"/"plot" of the data
I use this approach to keep my Pro and python/numpy environments clean and in the versions that I want.  But keep it in mind if you want to keep your work organized and separate.
Tags (3)
1 Comment
Contributors
About the Author
Retired Geomatics Instructor (also DanPatterson_Retired). Currently working on geometry projects (various) as they relate to GIS and spatial analysis. I use NumPy, python and kin and interface with ArcGIS Pro.
Labels
