Start with a polygons boundary.
Where are the unnecessary points?
Can you spot the redundant points? Original image on the left, cleaned image on the right?
Perhaps if I make it more obvious. A densified version of the inputs and the cleaned version.
Better?
The code
def _clean_segments_(a, tol=1e-06):
"""Remove overlaps and extra points on poly* segments. In `npg_geom_hlp`.
Parameters
a : array
The input array or a bit from a Geo array.
tol : float
The tolerance for determining whether a point deviates from a line.
Notes
- Segments along a straight line can overlap (a construction error).
[[0,0], [5, 5], [2, 2], [7, 7]] # points out of order
- Extraneous points can exist along a segment.
[[0,0], [2, 2], [5, 5], [7, 7]] # extra points not needed for line.
cr, ba, bc = _bit_crossproduct_(a, extras=True)
# -- avoid duplicating the 1st point (0).
whr = [i for i in np.nonzero(np.abs(cr) > tol)[0] if i != 0]
vals = np.concatenate((a[0][None, :], a[whr], a[-1][None, :]), axis=0)
return valsWhich calls
def _bit_crossproduct_(a, is_closed=True, extras=False):
"""Cross product.
Used by `is_convex`, `_angles_3pnt_` and `_clean_segments_`.
.. note::
np.cross for 2D arrays was deprecated in numpy 2.0, use `cross_2d`
def cross2d(x, y):
return x[..., 0] * y[..., 1] - x[..., 1] * y[..., 0]
if is_closed:
if np.allclose(a[0], a[-1]): # closed loop, remove dupl.
a = a[:-1]
ba = a - np.concatenate((a[-1][None, :], a[:-1]), axis=0)
bc = a - np.concatenate((a[1:], a[0][None, :]), axis=0)
# cr = np.cross(ba, bc) + 0.0 # deprecated
cr = cross2d(ba, bc)
if extras:
return cr, ba, bc
return cr
Now vals is a NumPy array which can be converted back to an arcpy shape using _arr_poly_ and _poly_to_array_ can be used to get the array(s) from arcpy geometry.
import arcpy
from arcpy import Array, Exists, Multipoint, Point, Polygon, Polyline
def _arr_poly_(arr, SR, as_type):
"""Slice the array where nan values appear, splitting them off."""
aa = [Point(*pairs) for pairs in arr]
if as_type.upper() == 'POLYGON':
poly = Polygon(Array(aa), SR)
elif as_type.upper() == 'POLYLINE':
poly = Polyline(Array(aa), SR)
return poly
def _poly_to_array_(polys):
"""Convert polyline or polygon shapes to arrays for use in numpy.
Parameters
polys : tuple, list
Polyline or polygons in a list/tuple
def _p2p_(poly):
"""Convert a single ``poly`` shape to numpy arrays or object."""
sub = []
pt = Point() # arcpy.Point()
for arr in poly:
pnts = [[p.X, p.Y] for p in arr if pt]
sub.append(np.asarray(pnts, dtype='O'))
return sub
if not isinstance(polys, (list, tuple)):
polys = [polys]
out = []
for poly in polys:
out.extend(_p2p_(poly)) # or append, extend it is
return out
Enough for now. More on my github page numpy geometry
