Building Python Add ins - enable/disable tool when a condition is met?
1087
06-25-2019 04:24 PM
GenevieveSimard
I am a beginner at Python coding and would require some help with ArcGIS Python Add ins.
I have created a TOOL which is working fine. I want to modify my code so this TOOL is enable only when a condition is met (in my case when a single point is selected from a predefined layer). The TOOL become disable when selection count <> 1
I have try a few things but I cannot find the correct place where to put my code for testing of that condition.
  • I tried in the  def __init__(self): this works when the tool is loaded, but does work afterward when the selection is updated
  • I tried to add a def onUpdate(self): to my TOOL class and modifying the config file (add onDemand="false") but that does not seem to do a difference , I am not sure if I can write such a function from this environment?
Here is  sample on my code:
class SetDLA_TOOL(object):
    """Implementation for StructureEditing_V1_addin.tool (Tool)"""
    def __init__(self):
        self.enabled = True
        mapdoc = arcpy.mapping.MapDocument("CURRENT")
        dfSTR = arcpy.mapping.ListDataFrames(mapdoc,"DEVELOPMENT (TEST) DATABASE")[0]
        primSTR = arcpy.mapping.ListLayers(mapdoc,"Primary Structure Symbol (BLACK)",dfSTR)[0]
        # Get a count of black selected structure
        primSTRfields = ["TIGER_PROD.ST_STRUCTURE_READING.DIP_LABEL_ANGLE"]
        rowCount1 = 0
        cursor1 = None
        with arcpy.da.SearchCursor(primSTR,primSTRfields) as cursor1:
            for row1 in cursor1:
                if row1[0] is None:
                    rowCount1 = 0
                else:
                    rowCount1 = rowCount1 + 1
            del row1, cursor1
        print ("RowCount1 is " + str(rowCount1))
        if rowCount1 == 1:
            self.enabled = True
        else:
            self.enabled = False
        self.shape = "NONE" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
#This works when the tool loads, but the enable/disabling of the tool is not updated afterward
    def onUpdate(self):   #Not sure if this def is legit for a tool class?
        rowCount1 = 0
        cursor1 = None
                if row1[0] is None:
                    rowCount1 = 0
                else:
            del row1, cursor1
        if rowCount1 == 1:
            self.enabled = True
        else:
    def onMouseDownMap(self, X1, Y1, button, shift):
#This is the body of the TOOL works fine but itself
        # Set variables
        secSTR = arcpy.mapping.ListLayers(mapdoc,"Secondary Structure Symbol - Dip < 90 (BLACK)",dfSTR)[0]
        primSTRfields = ["TIGER_PROD.ST_STRUCTURE_READING.DIP_LABEL_ANGLE","DMB.%ST_STRUCTURE_READING_EXTRA.MAP_GDA_X","DMB.%ST_STRUCTURE_READING_EXTRA.MAP_GDA_Y"]
        rowCount1 = 0
        cursor1 = None
                if row1[0] is None:
                    rowCount1 = 0
                else:
        if rowCount1 == 1:
            DLA = row1[0]
            X0 = row1[1]
            Y0 = row1[2]
        del row1, cursor1
        secSTRfields = ["TIGER_PROD.ST_STRUCTURE_READING.SECONDARY_DIP_LABEL_ANGLE","DMB.%ST_STRUCTURE_READING_EXTRA.MAP_GDA_X","DMB.%ST_STRUCTURE_READING_EXTRA.MAP_GDA_Y"]
        rowCount2 = 0
        cursor2 = None
        with arcpy.da.SearchCursor(secSTR,secSTRfields) as cursor2:
            for row2 in cursor2:
                if row2[0] is None:
                    rowCount2 = 0
                else:
                    rowCount2 = rowCount2 + 1
        if rowCount2 == 1:
            DLA = row2[0]
            X0 = row2[1]
            Y0 = row2[2]
        del row2, cursor2
        rowCountTotal = rowCount1 + rowCount2
        print ("RowCount2 is " + str(rowCount2))
        print ("RowCountTotal is " + str(rowCountTotal))
        if rowCountTotal <> 1:
            pythonaddins.MessageBox("You must have a single structure point selected to run this tool!","Warning")
            return
        if rowCountTotal == 1:
            self.enabled
        print("Current Dip label Angle is: " + str(DLA))
        # Coordinates of the mouse click are: X1,Y1
        # print("Your mouse click is at: " + str(X1) + " , " + str(Y1))
        # pythonaddins.MessageBox("Your mouse clicked at " + str(x) + " , " + str(y),"My Coordinates:")
        # Calculate the angle between the structure symbol and the mouse click
        angleRADIAN = math.atan2(Y1-Y0, X1-X0)
        # Convert the RADIAN angle to DEGREES angle and then to GEOGRAPHIC angle
        angleDEGREES = math.degrees(angleRADIAN)
        angleGEO = round((450 - angleDEGREES )% 360)
        # Set the Dip label Angle to GEOGRAPHIC angle derived from the mouse click
        arcpy.CalculateField_management(in_table="Symbols shown on map (BLACK)\Primary Structure Symbol (BLACK)", field="TIGER_PROD.ST_STRUCTURE_READING.DIP_LABEL_ANGLE", expression=angleGEO, expression_type="VB", code_block="")
        print("The dip label angle has been changed to: " + str(angleGEO))
        arcpy.RefreshTOC()
        arcpy.RefreshActiveView()
        mapdoc.save()
        del angleRADIAN, angleDEGREES, angleGEO
        del DLA,X0,Y0
        del rowCount1, rowCount2, rowCountTotal
        del dfSTR, primSTR, secSTR
        del mapdoc
Thanks for your help
Gen
