Warning 24171 when overwriting a map image layer
797
11-24-2025 09:09 AM
Shelby_Kline
When overwriting a map image layer that participates in multiple 1:M relationships and references registered data, I get the following warning:
24171: User assigned unique related IDs will not be honored
I have not manually set any relate IDs. When I view the layer in a new map viewer, its 2 related tables are not present.
I am using ArcGIS Pro 3.5.2 and ArcGIS Server 11.1. I see the Help post for this warning notes that unique relate IDs are not honored if "you are attempting to share as a web feature layer that copies all data
or you are attempting to share a layer or table to ArcGIS Server 11.2 or earlier".
The solutions offered are either unavailable to me or do not seem to work - I can't upgrade beyond 11.1 right now, but I am already sharing the layer and tables as a map image layer. The relate is needed in my web layer so I cannot remove it.
Has anyone else seen this? Any other suggestions?
Shelby_Kline
Hey David, unfortunately the only solution I found was going back to ArcGIS Pro 3.3. I'm guessing the issue was an incompatibility between our Pro and Enterprise versions.
DavidOGrady
Yes, experiencing this as well. Any luck with a solution?
Shelby_Kline
