Map extent tool
3725
09-24-2010 08:14 AM
toddsams
Is there a tool available on the Resource Center that can be used to obtain map extents?
DerekLaw
Esri Esteemed Contributor
Hi Todd,
The ArcGIS Viewer for Flex help documentation has a map extent helper tool designed for the Viewer application's configuration files. Its coordinate values are in Web Mercator.
Hope this helps,
nicogis
Where do you want use (ADF, js, sl ect)?
toddsams
Thanks Derek. I knew it was out there somewhere, just couldn't find it!
GavinRehkemper
Since that link is down, here are a few newer ones:
