Street Network - Analysis Settings - Restrictions
3341
10-07-2015 02:54 PM
BrentVan_Scoy__Fire_
When creating a network drive time, do you typically un-check the "Turn Restrictions" in the Analysis Settings?
This would seem to me to me a bit more realistic with creating a service area for emergency response.
Brent
ChrisDonohue__GISP
MVP Alum
It depends.  At the City I work for, we have a Street Network entirely devoted to Emergency Response and in it we have a valid turn restriction - an intersection in the old part of town where fire apparatus cannot make the turn as oneroad intersects another at a very shallow angle and turns to one side (almost 180 degrees) cannot be made as the turning radius is too narrow for the fire apparatus.
So is your Network used for multiple purposes?  Are the Turn Restrictions designed for normal vehicular traffic or for Emergency Response apparatus?  If the turn restrictions are along the lines of "No Left Turn" due to traffic considerations, then you can probably not use those in Emergency Response.
Chris Donohue, GISP
ChrisDonohue__GISP
MVP Alum
Chris Donohue, GISP
The street network is maintained by our County GIS department and is not specific for emergency response.  I will double check with them on the restrictions and make the determination from that.
Thank you for the response and image. It was very helpful.
Brent
