Having problems getting data driven scale to work
11381
15
12-12-2014 07:56 AM
StacyStanton
I am trying to use the data driven scale for a project I am working on and it does not seem to be working.  I am working on a Fire Department Box book and the data driven pages are set to be based on the box boundaries.  I added another column to the box boundary attribute table for the scale and put in what I wanted each page to be scaled at ex: 3600 or 4800 etc.  When I set the scale to be data driven and use that attribute it does not change the scale to what I set it for.  What am I doing wrong?
Tags (1)
JamesFitzgerald
Hello Stacy,
Click on the 'Set Up Data Driven Pages' icon and click on the second tab called Extent. Click the Data Driven Scale radio button. From the drop down menu, select the attribute field with the scale. This work for me using my data.
James
StacyStanton
I have tried that and it doesn’t seem to work.
Stacy L. Stanton
Administrative Assistant
Department of Public Works
Village of Churchville
Phone: 585-293-3366
Fax: 585-293-3693
JamesFitzgerald
Hello Stacy,
Can you send me a sample of your data? (Shapefile.shp) Not sure what exactly is going on with your problem.
Thanks
James
StacyStanton
Let me know if you need anything else.
Thanks!
Stacy L Stanton
Village Of Churchville
Secretary for the Department of Public Works
www.churchville.net<http://www.churchville.net>
585-293-3366 Phone
585-293-3693 Fax
JamesFitzgerald
Did not receive sample?
Thanks
StacyStanton
I replied via email and attached it to that and it didn't carry over to the web. I don't see something on here that allows me to attach something.
JamesFitzgerald
Hello,
You can create a new discussion and attach the zipped shapefile and send it directly to me. To do this task, find the icon with the pencil and drop down menu. Choose the Discussion...there is a attach in the lower right corner.
Thanks
JamesFitzgerald
Hey Stacy,
Where are the BOX-BOUNDARIES located? Village of Churchville? I believe the reason you cannot get the scale to work is because of projection. The file you gave me is undefined.
Thanks
JamesFitzgerald
Hello Stacy,
Where did you get the file Box Boundaries? Shapefile.shp? CAD.dwg fie? I believe if you fix the projection it will work. Data driven pages does not recognize the scale since it is not projected.
