Failed to Execute (Make Map)
2706
05-09-2014 03:01 AM
CodyHudson
So i've followed the instructions that come with the install step by step but I still get the error 'Failed to Execute (Make Map)'  Any suggestions? Running 10.1 and downloaded proper 10.1 version of MapSAR. This is very frustrating. I've also noted that the ebook manual DOES NOT correlate with MapSAR...at least on my end. Files/Folders don't match up by name.
JonPedder
Sorry to hear you�??re running into problems. You�??re quite right about the manual, as we're aware that it doesn�??t reflect accurately the current version, there is an update in the works.
As for your error executing Make Map, it would help if you could provide me more detail. Can you please provide information on when you get the error and maybe a screenshot or paste the results.
Jon
