ERDAS Imagine 32bit
2040
01-24-2025 05:36 AM
BrianLomas
Hello, I have an ERDAS 32bit DEM that I am trying to make into contours. This is my first time dealing with this type of imagery so bare with me. No matter what analysis I run on it (copy raster, clip, raster calculator, export etc.) the resulting image is all one value. Also, when I identify a pixel in the the value is empty on the ERDAS dem (I believe this is normal for a 32bit float)(properties attached). However the image displays fine so I know there is a "value" somewhere it is using to display. I'm assuming this is all do to lack of my knowledge of this file type but how do I run analysis like copy raster or clip on an ERDAS Imagine image 32bit float file? TIA.
RandallRebello
Hi Brian,
You have posted this query in the wrong section. Try ArcGIS Image Analyst or ArcGIS Image Server for an answer.
Randall
