OIC GP Tool "Type Error Can Not Read Property 'Split' of  Undefined"
1871
01-19-2022 08:15 AM
StanLebrun
I am running into an "Type Error Can Not Read Property 'Split' of  Undefined" when running the OIC GP tool. I am also noticing this a warning when analyzing the OIC; "Checking for local images and default values... Local images found! Local Images will only load in the viewer if used by ArcGIS Pro Addin. Please run the Select Local Images GP Tool to identify the local images." I am able to publish the OIC and all the associated contains to ArcGIS Enterprise, but I am unable to view the images.
Any help with this issue would be greatly appreciated.
MattiasTivlin
Hi! Have you solved this issue? I have exact the same problem so a solution would be nice 🙂
