Issue when running the Create Coverage Features in the Tutorial
1559
08-10-2024 10:29 AM
MiguelParedes
Greetings All,
When I go through the Tutorial in Create an oriented imagery catalog Tutorial, I am getting stuck in step 4. when running the Create Coverage Features GP tool.  The tool completes successfully, but no polygons are created. When I view the details, I get the following message: Update Available. Please read...
I am using the ArcGIS Pro Addin for ArcGIS Pro 3.3, with ArcGIS Pro 3.3.0.
with the Oriented Imagery Classic Management Tools for ArcGIS Pro  Version 2.16 (Released February 2024)
Is there a new version of the tools, and if so, does anyone know where I could get it from?
I really appreciate any help you can provide.
Miguel
RandallRebello
Hi Miguel,
Can you check that you have all the values (in attribute table and OIC Properties.) required to create a coverage map. Those properties would be CamHeading, CamPitch, CamRoll, AvgHtAG, VFOV,HFOV,NearDist,FarDist and OIType.
There should be valid values in either the attribute table or OIC Properties.
Randall
MiguelParedes
@RandallRebello
Greetings Randal,
Thank you for responding.
Yes, I have all the values filled in:
I have tried the above with Pro 3.2.0 and the corresponding tools and the same with Pro 3.3.0. Both yielded the same problem.
Miguel
MikeTownshend
Hello,
Have you found a resolution for this issue?  I am running into the exact same problem with the OIC tutorial and ArcGIS Pro 3.4.0.
Disregard...  Use tools built into ArcGIS Pro 3.4
