Adding a video to oriented imagery catalog
8020
11
10-13-2021 10:45 PM
PeterMacKenzie2
I am attempting to add a mp4 video to an Oriented Imagery Catalog (v2.7) in Pro (2.8.3) using an external csv table for metadata. This is mostly blank other than these key fields.
UnixTimeStampSensorLatitudeSensorLongitudeSensorEllipsoidHeight
Is this even possible or do I need the image analyst extension and then follow the Full Motion Video (FMV)/multiplex documentation?
I'm following the OrientedImageryCatalogManagement_UserGuide.pdf but there is very little info about how to do what I am trying to do.
Note: I am currently getting this error: Log attached, Metadata File attached.
Calling GeospatialVideo
Error in processing images. name 'log' is not defined
note:  i've been able to add images OK.
Tags (1)
PeterMacKenzie2
ok thanks, I sent you a message with a GoogleDrive link, cheers
PeterMacKenzie2
I'm wondering the time interval of my csv metadata is critical here. I probably need one row per second so that a 1 or 2 second frame rate in the tool will work (i.e. it probably doesn't interpolate values).
