Problem with L.esri.FeatureLayer and map panes
2001
03-04-2020 03:32 PM
JosephElfelt1
Each Layer I add to my map goes into its own custom pane.  Each custom pane is assigned a zindex starting with 401 so I can control the stacking order.  I  do the following.
1. Add FeatureLayer, pane = "pane_401", zindex = 401
2. Add DynamicMapLayer, pane = "pane_402", zindex = 402
3. Remove the FeatureLayer from the map
4. Add the FeatureLayer, pane = "pane_403", zindex = 403
The FeatureLayer should be on top of the DynamicMapLayer but it is not, it is underneath.
If I am only adding/deleting DynamicMapLayers then the stacking order on the map is fine.
Obviously there is something about FeatureLayer that I am not understanding.
Can anyone point me in the right direction?
Tags (3)
JosephElfelt1
Apparently if you have a FeatureServer layer that you:
add to the map
remove from the map
add to the map again
then when you re-add it to the map you *must* use the original pane where you placed the FeatureServer layer.  It is OK to change the zindex to control the stacking order.  But you should not make  a new pane when you add FeatureServer data that you previously added to your map and then deleted.
My map works fine now.
JosephElfelt1
add to the map
remove from the map
