geoprocessing service no response with Leaflet
6107
12
12-01-2018 09:32 AM
GrantHaynes
Hi all,
I'm using leaflet to create a time series web map where a user can place a point on a map and the values at that lat and long will be graphed on the web page. I have a geoprocessing service that runs fine, I've tested it in arcmap and it works great it accepts lats and longs and spits out the extracted data values. I also have a web page that allows a user to create points and produces lats and longs to be passed back to the geoprocessing service. However I cannot get the two to talk to each other, can anyone here tell me what is wrong?
<!-- Map processes here -->
<div id = "map">
<script type='text/javascript'>
var map = L.map('map').setView([0, 0], 2);
L.esri.basemapLayer('Gray').addTo(map);
map.on('click', addMarker);
var MarkerLayer = new L.FeatureGroup();
map.addLayer(MarkerLayer);
var Coordinates = [];
function addMarker(e){
Marker = new L.marker(e.latlng).addTo(MarkerLayer);
Coordinates.push(e.latlng);
function ClearMarker(){
MarkerLayer.clearLayers();
Coordinates = [];
function Geoprocessing(){
// Go through coordinates generated from leaflet and split them
// up to be passed to the geoprocessing service
Coordinates.forEach(function(item){
var Results = [];
var StrItem = String(item);
var StrParts = StrItem.split(",");
var Lat = StrParts[0].slice(7);
var Long = StrParts[1].substring(0, StrParts[1].length - 1);
//execute geoprocessing service each time a lat and long are generated
var gpService = L.esri.GP.service({
useCors:false
var gpTask = gpService.createTask();
gpTask.setParam("InputX", Long);
gpTask.setParam("InputY", Lat);
gpTask.run(DataCallBack);
// Handle server response
function DataCallBack(error, raw, response)
window.alert(error.message);
</script>
GrantHaynes
Thanks, I fixed the URL and I'm getting a response from the service. Do you know how synchronous geoprocessing services return non layer results? Is it dictated by the output data type of the published geoprocessing task?
JohnGravois
yup. you can configure GP services to output all sorts of different results.
GrantHaynes
That's what I thought, this service as it stands returns a text file, I want the values in the text file for graphing in the web browser. I'm pretty sure I need to change the script and republish the service with a result data type that is more suitable, but is there a way to achieve that with the existing service?
