ESRI leaflet Service Area size not alterable
1174
05-21-2022 01:45 AM
VictorEssang
Please I need urgent help with this. I've attempted to change the drive time values of the service area for so as to see a change in size in the service polygon but the polygon size still remains the same.
I've hard-coded it to change but the size still remains the same.
Please how can I change this, I need to be able to change the drive time inorder for the service area polygon size to be changed.
Ill appreciate any assistance on it. Thanks
GavinRehkemper
Hi, thank you for the question. Can you please post an example of the code that is not working properly for you? You can find more information about using Service Areas with Esri Leaflet in this tutorial: Find Service Areas.
