ESRI geocoder - Does *all* use now require a token?
4378
07-13-2021 01:59 PM
JosephElfelt1
I have a leaflet map that uses the ESRI geocoder. My map gets one location per request, displays that spot on the map[ and does not save the data.
This page says using ESRI's geocoder in that manner is free: https://developers.arcgis.com/rest/geocode/api-reference/geocoding-free-vs-paid.htm
However, today the geocoder sends my map this message:
"code": 499, "message": "Token Required"
Can anyone shed light?
John-Foster
Please try the update. We did note in the github repo the updated terms https://github.com/esri/esri-leaflet#terms, the API key is going to be required.
--jf
John-Foster
@JosephElfelt1 did you see this page that shows the steps to set up Leaflet with the geocode service?
https://developers.arcgis.com/esri-leaflet/geocode-and-search/search-for-an-address/
it should have all the steps you need to get an API key and add that to your Leaflet app use the geocode service.
--jf
JosephElfelt1
I have been using the following geocoding service which is in the ESRI Leaflet documentation.  L.esri.Geocoding.geocode()
And it has worked fine without an API key or token up until just recently.
  But if necessary I can switch to the REST API geocoding service.
John-Foster
--jf
JosephElfelt1
Thanks for the info John.  I will review the TOS and use the update.
