Why are unavailable tools listed?
4363
09-05-2014 09:59 AM
BruceLang
Is there a GOOD reason why ESRI continues to display toolboxes and tools in the "system toolboxes" for extensions which are not installed?
It's frustrating to locate a tool, to accomplish some task, only to find it cannot be used.
I've submitted this request to the Ideas section back in 2010 http://ideas.arcgis.com/ideaView?id=087300000008HzXAAU
Thanks in advance.
DanPatterson_Retired
Now I get it...it is far easier to include the whole lot and manage it by license level rather than distribute separate versions based upon that level.  Also, the advantage is that you can examine the functionality via the help files etc without purchasing a higher level of the software
You can toggle it off...simply right click on Arctoolbox at the top of the Arctoolbox tree and choose to hide those tools that you don't have a license for...you won't see them again
BruceLang
Thanks Dan,
The "Hide Locked Tools" setting is already checked on the R-Click properties of the "ArcToolBox" within ArcMap Desktop. Tried turning this setting off then back on, but no change.
The "Hide Locked Tools" is also "checked" in ArcCatalog too.
