visualize geocode data
3712
12-15-2015 07:23 AM
RiccardoPirovano
Hi, im new with ArcGis. I have a DB with name and addres (lat, long) and I would like to visualize them on a map, do you know any guide or tutorial to teach me?
thank you
MitchHolley1
Use this geocoder : GPS Visualizer's Easy Batch Geocoder  and select 'Batch Geocode'
From here, you can copy and paste the coordinate results into a table --> create a feature class from the X,Y values in ArcCatalog --> navigate to the table in your DB, right click and select 'Create Feature Class', select a Coordinate System
I think I listed the steps properly.
WesMiller
If you have lats and longs you should be able to (in arcmap) select file add data add xy data
