Projection in AGOL?
5070
03-08-2019 11:35 AM
by Anonymous User
Not applicable
When I publish a feature layer to ArcGIS Online, is it automatically converted to WGS84 Web Mercator (Auxiliary Sphere)?
JohnBrockwell
It projects 'on the fly'. If you are using a large dataset or many layers in a web app. I recommend projecting to Web Mercator Aux and then creating a web layer.
JohnBrockwell
RobertBorchert
Honored Contributor
We have all of our data stored in WGS 1984 Web Mercator (auxiliary sphere) as that is the most compatible for large areas and displaying online.
As John responded.  I would suggest switching to that projection for online work.
by Anonymous User
Not applicable
Hi Matthew,
Yep that's right, and John has a great suggestion. Portal will keep the projection of the data published, but in ArcGIS Online it is all displayed in Web Mercator Aux.
by Anonymous User
Not applicable
Thanks everyone for the responses!  I might have some follow up questions, but for now that helps...
