I'm trying to export attribute fields to CAD using ArcGIS 10. Creating point feature classes for my parcel labels was accomplished using the Feature to Point tool and then Field Calculator to populate new fields with my parcel data. However, the 'stacked
3142
12-05-2014 09:08 AM
BernieMarocco
ArcGIS10: Exporting attribute fields to CAD
I'm trying to export attribute fields to CAD using ArcGIS 10. Creating point feature classes for ArcMAP parcel labels was accomplished using the Feature to Point tool and then Field Calculator to populate new attribute fields with parcel data from multiple fields. However, the 'stacked text' labels that I exported went in to CAD with some unwanted additions. Each line ended with a "?" and the stacking was no longer centered. I'm not sure if it's an issue with the VBScript in the Field Calculator run or the method/field size for populating the attribute fields with this stacked text data. No error or warning messages were generated in the process. Any suggestions would be appreciated. bj marocco
