How to create a multiple ring buffer from existing buffers
2263
06-08-2017 05:24 AM
EllenWildig
I have a set of buffers from 5-200m from a scheme at one metre intervals. Is there a way to make each buffer a ring, one metre wide, around the scheme? Alternatively, if I create new multiple buffers around the scheme which align with the existing ones, is there a way to spatially join the layers, but so that the attributes of the topmost existing buffer are the only ones retrieved by the new buffers?
Ellen
AbdullahAnter
Honored Contributor
Sorry, I am don't understand whole question . but  I think the answer of the following question
Is
Check on Outside polygons only while you using multiple Ring Buffer tool.
