ArcView Online Grayed Out - Cannot get base maps.
5153
04-29-2014 01:19 PM
PaulRosholt
I have completed registration of my ERSI Global Account, ArcView 10.1 allows me to sign in under "File - Sign In", yet ArcView Online  and ArcView Online options under "Add Data" remain grayed out.  Is there some other simple step I am missing?
PaulRosholt
After many searches of the ESRI Forums, finally found an answer.  One little check box in internet tools LAN settings:
Re: ArcGIS Connection has stopped working
The following suggestion should resolve the issue:
1. Open Internet Explorer-> Tools->Internet Options->Connections-> LAN Settings and turn off "Automatically detect settings."
Other Suggestions
1. Navigate to Control Panel->Add/Remove Programs->Select ArcGIS Explorer for Desktop ->Uninstall/change->Repair.
2. Try to ensure that you have the most current display driver installed on your client machine. Open Control Panel > Device Manager. Expand Display Adapters. Right click the adapter below this > Properties. Go to the Driver tab > Update Driver > Search Automatically. If you can upgrade, then install the newer driver.
3. http://cyri.systemrequirementslab.co..._if/1186/10895 Use ArcGIS Explorer behind a firewall: http://webhelp.esri.com/arcgisexplor...n/firewall.htm
Regards,
Robert LeClair
Esri-Denver
Hope this helps anyone else stuck in the first exercise of the workbook...
PaulRosholt
Other Suggestions
Regards,
Robert LeClair
Esri-Denver
