WMS Exception: XML comment is not well-formed (v100.2)
1900
02-14-2018 11:56 AM
KeithGemeinhart1
I'm trying to interact with a WMS service hosted on a GeoServer v.2.8.5. I can hit the URLs and view an openlayers version of the data in a web browser, but while trying to follow the WMS examples, I get the following exception:
"Invalid XML.: XML comment is not well-formed"
Same problem occurs using code from ArcGISRuntime.WPF.Samples.WmsServiceCatalog sample and ArcGISRuntime.WPF.Samples.WmsIdentify sample ... on the corresponding LoadAsync() call.
Tags (3)
MichaelBranscomb
Esri Frequent Contributor
Can you share the service for us to test against? (it's possible we've already addressed this in the current code).
Cheers
Mike
KeithGemeinhart1
Is there a way for me to send it in a private message?
MatveiStefarov
Keith Gemeinhart‌ — We just released Runtime patch 100.2.1, which contains several WMS-related bug fixes and improvements. There is a good chance that this new version of Runtime will work well with your services. Please try it out!
