This article seem to cover a bit half way down how to add the VCLibs as a dependency: https://learn.microsoft.com/en-us/windows/msix/desktop/desktop-to-uwp-prepare
It does look like if I add the following, that it shows up in the manifest of the generated app package, but no idea if that'll do the trick:
You could at least start with confirming whether it is a vclibs issue on the machine where you can reproduce, by installing the C++ Redistributable and verify if that addresses it.
Here is the publish result: WinuiTest_1.0.4.0_Test.zip
I wonder if the machine is missing the C++ redistributable which is listed as a requirement for the .NET SDK (Visual Studio installs this too which explains why VS is fixing the crash)
You could also try and use ProcDump to get a better idea why it is crashing. I've seen weird crashes like this in WinUI, and the error does point to their module.
That was it!
After installing VC redist, no crash.
By adding <WinUISDKReferences>true</WinUISDKReferences> in the csproj, 2 VCLibs packages are published :
The app now works without the need to install VC redist.
Thanks!
Great! Nice find on WinUISDKReferences property.
