Widget location in a web mapping application do not work in MAUI
1446
02-17-2025 12:51 AM
ArnaultDicka
Hi community,
I am loading a web mapping application, from my Arcgis enterprise shared for public with full privileges, in my MAUI application.
The location widget, located in the web mapping app. returns "Location dinied". But when I open it in any web explorer, it works perfectly.
here is my code in MainPage.xaml:
<WebView x:Name="MyWebView"
Source="https://xyzxyzxyzx/portal/apps/webappviewer/index.html?id=124f8e1fcd8141319cd51655b64d446e"
HorizontalOptions="FillAndExpand"
VerticalOptions="FillAndExpand" />
In AndroidManifest.xml :
<manifest xmlns:android="http://schemas.android.com/apk/res/android">
<application android:allowBackup="true" android:icon="@mipmap/appicon" android:roundIcon="@mipmap/appicon_round" android:supportsRtl="true"></application>
<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
<uses-permission android:name="android.permission.INTERNET" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
</manifest>
Please, Help
GKmieliauskas
You also need to explicitly include logic in your app to request this permission at run-time.
                var status = await Permissions.CheckStatusAsync<Permissions.LocationWhenInUse>();
                // Request location permission if not granted.
                if (status != PermissionStatus.Granted)
                    status = await Permissions.RequestAsync<Permissions.LocationWhenInUse>();
ArnaultDicka
thanks for your answer.
Please, how con I do that ?
ArnaultDicka
there is what i have in codes
       private async void CheckAndRequestLocationPermission()
            if (status == PermissionStatus.Granted)
                GetLocation();
            else
                await DisplayAlert("Permission Denied", "Unable to access location.", "OK");
dotMorten_esri
Esri Notable Contributor
Since you aren't using the Maps SDK for .NET MAUI but using the JavaScript SDK, it's not quite the right forum. However a quick google search reveals a few settings and things you need to do to enable location in embedded webviews: https://stackoverflow.com/questions/5329662/android-webview-geolocation
