What's the detail differents between ArcGIS Runtime for WPF and ArcGIS Runtime for .Net?
4130
06-07-2015 05:00 AM
YangJason
Hi,I'd want to know what detial differents between ArcGIS Runtime for .Net and WPF.As you know,I used WPF in the past,now 10.2.5 is the last relased version,so I have to turned to ArcGIS Runtime for .Net. So is there any documents show the differents between them? thank you.
FreddieGibson
Honored Contributor
I don't believe there is a page that specifically states every difference between the WPF and .NET runtimes, but there are a couple of blogs available for you to review that could reveal some major differences.
Getting ready for the new ArcGIS Runtime SDK for the Microsoft .NET Framework
http://blogs.esri.com/esri/arcgis/2014/03/07/getting-ready-for-the-new-net-sdk/
DS2014: Migrating Your WPF Apps to the New ArcGIS Runtime SDK For .NET
http://www.arcgis.com/home/item.html?id=bc2feb8ce40942189458c882594684c6
Other than what is covered in the above articles, is there anything in particular that you wanted to know the differences between? I know in the beginning I used to use the WPF Runtime and now I primarily use .NET. I determined most of the differences in the approach by comparing the guide portions of the help between the two products.
KeithGemeinhart
I would recommend watching this presentation from this year's Dev Summit. It should answer your questions. http://www.arcgis.com/home/item.html?id=865907613bdd4f1bae1f0537f5a48d84
