Does using local GeoTiff file as a raster data in the operational layer of the map require certain liscense?
Hi Bikash,
To access the local raster layer such as .tiff file you need to have "Standard" license. Please look at the documentation link:
License your app—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers --> Licensing capabilities --> Standard.
Hope that helps.
Hey Nagma,
Thanks for quick response. When it is licensed for developer use only, I can access the local raster layer right to test it?
Hi Bikash
Yes, you are right, with licensed for developer use only, you could access the local raster layer.
Thanks Nagma! It works. The only problem is when i keep zooming out, the .tiff data dissapears automatically before I can even see the whole raster data on my screen. Is there a default setting that makes it happen or is it just the .tiff file that only appears in certain zoom levels?
Are you using Xamarin,there is a bug logged regarding this issue:
RasterLayers disappear when zooming out in Xamarin UWP application for .NET SDK v100.1.]
