Upgrading from ArcObjects - CreateRasterDataset
3401
10
05-22-2024 09:03 AM
DharmeshPatel1
I am trying to upgrade a C# project that has been using ArcObjects 10.7.0.0 to now use ArcGIS Maps SDK for .NET . We use the CreateRasterDataset method from https://developers.arcgis.com/enterprise-sdk/api-reference/net/IRasterWorkspace2/
Please could anyone assist me in how I would get the same method in the latest ArcGIS Maps SDK .NET or what methods there are to do this CreateRasterDataset.
Thank you.
MichaelBranscomb
Esri Frequent Contributor
Can you share any more information about how you use the CreateRasterDataset function?
e.g.
  • Are these single band or multi-band raster datasets?
  • Do you create single, standalone raster datasets or do you mosaic multiple raster datasets into a single image?
  • Do you need to update/replace images or update pixels/cells within rasters?
  • What type/format are you creating e.g. JPEG, TIFF, or geodatabase raster dataset?
  • Do you need to specify compression when creating JPEG file or geodatabase rasters?
  • Do you need to build pyramids? (improves the display performance of raster datasets)
  • Do you need to calculate statistics? (allows applications to properly stretch and symbolize raster data for display)
Mike
