TiledMapServiceLayer options
1913
04-03-2019 01:40 PM
MauricioRamirez1
We're experiencing a situation where the tiles for our basemap are not all coming through right away.  When we run wireshark, we notice there are lots of 304 returns from the network proxy.  Is there a way to force the requests not to be cached?  Are we able to change the timeouts so that tiles can be re-requested when the 304 returns?  We are using .net runtime 10.2.7
dotMorten_esri
Esri Notable Contributor
304 returns should be fine. Why would those be an issue? (304 is basically just the server's way of saying "don't bother downloading the tile again - the tile you have in your cache is the same, so use that instead" and should make tile loading faster).
Are you sure the 304s are the reason some tiles are not all coming through?
MauricioRamirez1
I'm assuming  that's the case as I just opened the app and browsed to a random place I hadn't browsed to.
dotMorten_esri
The cache is the shared browser cache that all apps/browsers share, so could be the tiles was hit at a different time?
Alternatively your browser cache might be corrupt. Try blowing it away
MauricioRamirez1
Tried blowing out the cache and still seeing the same.  If the 304s are not the reason, what could be?
