Just starting out working from WPF client and was confused what the difference between the toolkit and sdk is ? I noticed there is a seperate sdk for the arcgis pro.... how is that different from the runtime sdk?
Found a large number of samples including
GitHub - Esri/arcgis-toolkit-dotnet: Toolkit for ArcGIS Runtime SDK for .NET
and not sure where to start.
Have you gone through the developer site? ArcGIS for Developers
In regards to your basic question the Runtime SDK is the core API. This is what any application is built on top of. The toolkit is a number of controls (which are common in mapping application), built using the Runtime SDK that can be used in an application. The toolkit is just something esri provides to help developers, it is not required.
A good place to start would be setting up the demo applications from github. This will show you some code for many standard types of mapping functionality and all the code to do it
Thanks for clarifications,
Just one more thing, what is the difference arcgis-pro-sdk and the arcgis-runtime-sdk?
ArcGIS Pro is an esri product, the arcgis-pro-sdk is for writing applications to customize ArcGIS Pro. arcgis-runtime-sdk is for writing stand alone apps to run on Windows, Android, and iOS. The provide APIs to write native apps on those platforms (Windows both WPF and UWP). Also an API that can be used with Xamarin for cross platform development
