Pro SDK (.NET) console app + Utility Network: can’t see/edit branch versions (only DEFAULT returned)
314
03-11-2026 08:15 PM
OscarYam
Hi all,
I’ve been asked to build a .NET console application using the ArcGIS Pro SDK to edit features in a Utility Network. Since UN uses branch versioning, I shouldn’t edit DEFAULT directly—I need to connect to and edit a named branch version.
Environment
  • ArcGIS Pro: 3.1.4
  • .NET: 6.0
  • Database: SQL Server
  • Connection: Enterprise Geodatabase direct connect
What I tried (Enterprise Geodatabase connection)
I create a Geodatabase using DatabaseConnectionProperties and specify a version name in the connection properties. I tried different version name formats such as:
  • versionName
  • user@domain.versionName (and similar fully-qualified formats)
But when I do that, the constructor throws:
  • Exception: “The specified version does not exist.”
The version definitely exists (it’s created in Pro before I run the test).
What I observed
If I create the Geodatabase without specifying a version and then call:
  • Geodatabase.GetVersions()
…it returns only one version: DEFAULT. No child versions show up under DEFAULT either.
I also checked whether the geodatabase supports versioning and what versioning type it is. It reports:
  • Supports versioning: Yes
  • Versioning type: Traditional
Attempted alternative (service-based)
Since branch versions are tied to services, I tried using a service geodatabase approach, but in my console project Visual Studio shows:
  • Compile error: ‘ServiceGeodatabase’ is inaccessible due to its protection level
So I can’t even instantiate/use ServiceGeodatabase from my code.
Questions
  1. Is this likely a database/enterprise geodatabase configuration issue (or expected behavior when using direct connect with branch versioning)?
  2. Is there a supported alternative to connect/edit a specific branch version besides direct connect + version in DatabaseConnectionProperties?
  3. For testing with ServiceGeodatabase: is there any way to resolve the compile error, or is this class intentionally not public? If it’s not meant to be used, what is the correct public API to use instead?
RichRuh
Branch versioning only works through a feature service connection.
Instructions for creating a connection to a feature service geodatabase can be found here: https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-Geodatabase#geodatabase
