Offline Desktop Pattern - Advanced Labeling
2087
05-30-2016 05:03 AM
JensBuchta
I'm trying to create some offline content for the ArcGIS Runtime using the Desktop Pattern (export data using ArcMap).
Some of the layers in ArcMap have an advanced labeling like (VBcript) "[Field_1] & [Field_2]". Unfortunately, the Create ArcGIS Runtime Tool fails with the message "Layer expression not supported".
As the ArcGIS Runtime is able to handle such a label expression as described in Label map features—ArcGIS Runtime SDK for .NET | ArcGIS for Developers , referring to the ArcGIS Server REST API "[Field_1] CONCAT [Field_2]", I wonder how to prepare the data in ArcMap to avoid having custom code in ArcGIS Runtime. I tried all VBScript, JScript and Python but eventually failed.
Is it possible to prepare the Labeling expression in ArcMap in a way, the Create Runtime Content tool supports the conversion?
Kind Regards
Jens
