Map not displaying in release APK for Xamarin Android v100
1979
02-12-2017 09:14 PM
EdL
Hi
I have just created an an application on visual studio 2015 using v100 runtime for .Net on Android platform. After testing, the source code for the application will be checked into Team Foundation Server (TFS) where it will create a release APK build.
After building and installing the APK on my android mobile device, I find that the map fragment is not loading the map (black background only). I have checked that the ESRI runtime DLLs have been added to the TFS and the project is referencing the file correctly.
Does ESRI require any license to build a release APK?
Does TFS require any configuration?
What is the likely problem?
