Mac Catalyst Release publish fails with ArcGIS Maps SDK for .NET MAUI 200.8.1 (Info.plist merge error)
744
03-15-2026 07:55 AM
sindrevr
I can reproduce a Mac Catalyst Release publish failure in a clean .NET MAUI project when adding Esri.ArcGISRuntime.Maui 200.8.1.
A standard MAUI template publishes successfully for Mac Catalyst. However, after adding the ArcGIS package and initializing it with .UseArcGISRuntime(), the architecture-specific builds succeed but the final universal app merge fails.
Environment
  • ArcGIS Maps SDK for .NET MAUI: 200.8.1
  • Target: net10.0-maccatalyst
  • Machine: Apple Silicon MacBook Pro
  • Build command:
dotnet publish -f net10.0-maccatalyst -c Release
Steps to reproduce
Create a new MAUI project
dotnet new maui -n MauiApp1
cd MauiApp1
Publish Mac Catalyst Release
This succeeds.
Add ArcGIS NuGet package
<PackageReference Include="Esri.ArcGISRuntime.Maui" Version="200.8.1" />
Initialize ArcGIS in MauiProgram.cs
builder.UseArcGISRuntime();
Publish again
Result
Both architecture builds succeed:
  • maccatalyst-x64
  • maccatalyst-arm64
But the final universal bundle merge fails with:
Unable to merge the file
Contents/Frameworks/RuntimeCoreNet.framework/Versions/A/Resources/Info.plist
it's different between the input app bundles.
Investigation
Comparing the generated files shows different CFBundleIdentifier values inside RuntimeCoreNet.framework:
arm64
com.esri.ArcGISXamarinArm64
x64
com.esri.ArcGISXamarinSimx64
This difference appears to cause the universal Mac Catalyst bundle merge to fail.
Workaround
Publishing a single architecture works:
dotnet publish -f net10.0-maccatalyst -c Release -p:RuntimeIdentifier=maccatalyst-arm64
Question
Is this a known issue with the ArcGIS Maps SDK for .NET MAUI 200.8.1 packaging for Mac Catalyst?
Thanks.
Praveenaa
This is by design and not specific to 200.8.1 . It applies all versions of the ArcGIS Maps SDK for .NET MAUI on Mac Catalyst. You will need to specify a single architecture at publish time, as you already found.
Praveenaa
The Mac Catalyst universal publish issue has been resolved. If you upgrade the package reference to ArcGIS Maps SDK for .NET MAUI 300.0, the workaround is no longer needed. You should be able to publish without restricting to a single architecture:
