LocalMapService load .mpk map fail
7205
12
07-05-2015 08:39 PM
坤王
map don't load mpk map. debug it only execute  await localMapService.StartAsync();  why?
code:
public async void CreateLocalServiceAndDynamicLayer()
            try
                LocalMapService localMapService = new LocalMapService(@"maps\water-distribution-network.mpk");
                ArcGISDynamicMapServiceLayer arcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer()
                    ID = "arcGISDynamicMapServiceLayer",
                    ServiceUri = localMapService.UrlMapService,
                MyMapView.Map.Layers.Add(arcGISDynamicMapServiceLayer);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
AnttiKajanus1
We fixed issues with directory paths with multi-byte chars in 10.2.6 release. Please update to that and let us know if you are still seeing this issue.
  • BUG-000083073: ArcGIS Runtime apps fail to execute when run within a directory that contains a multi-byte character.
坤王
I use 10.2.5 before, but now I use 10.2.6 and report the same fault.
And i don't see "BUG-000083073" error.How to see it?
MichaelBranscomb
Esri Frequent Contributor
It's still hard to tell exactly what the problem is. Possibly there is an issue unpacking the MPK and starting the local map service, although this should raise an exception which will be caught in the try/catch around the awaited StartAsync call. To help determine this you can enable LocalServer logging following the instructions on Work with local services—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Cheers
Mike
