Load DLL referencing other native DLL (RuntimeCoreNet100_11_2.dll)
3392
5
07-19-2021 04:49 AM
SOTIRIOSTRIANTOS
When i am trying to consume a dll that uses an mmpk in order to use its locator, i get the following error "The type initializer for 'RuntimeCoreNet.GeneratedWrappers.CoreMobileMapPackage' threw an exception."  the inner exception message shows "Invalid ArcGISRuntime deployment folder, missing folder arcgisruntime100.11\client32"
The problem is that i am forced to use a windows form to call the locator's  dll, otherwise the locator's dll works fine (i.e a wpf application)
Any ideas? i tried using ilmerge with no succes since i cannot find any documentation.
MichaelBranscomb
Esri Frequent Contributor
Can you provide more detail about your project/application type or even attach a small repro project?
Deployment info for .NET Framework and .NET Core/.NET is available here, but if you find it's insufficient we'd love to enhance it.
SOTIRIOSTRIANTOS
Hi there and thank you very much for you prompt reply. To put it simply  i am trying to call the below dll (wpf library class)
    public class MapViewModel : INotifyPropertyChanged
        //Static Fields
        public static LocatorTask _geocoder;
        public event PropertyChangedEventHandler PropertyChanged;
        /// <summary>
        /// Raises the <see cref="MapViewModel.PropertyChanged" /> event
        /// </summary>
        /// <param name="propertyName">The name of the property that has changed</param>
        protected void OnPropertyChanged([CallerMemberName] string propertyName = null)
            var propertyChangedHandler = PropertyChanged;
            if (propertyChangedHandler != null)
                propertyChangedHandler(this, new PropertyChangedEventArgs(propertyName));
        public static async Task ConfigureStreetMapPremium()
            // Get the path to the map package
            string streetMapPremiumPath = @"C:\Users\*********\source\repos\*****\****\bin\Debug\myMap.mmpk";
            //string streetMapPremiumPath = System.IO.Path.Combine(System.IO.Directory.GetCurrentDirectory(), "myMap.mmpk");
            //string streetMapPremiumPath = AppDomain.CurrentDomain.BaseDirectory + "myMap.mmpk";
            try
                // Load the package
                MobileMapPackage streetMapPremiumPackage = await MobileMapPackage.OpenAsync(streetMapPremiumPath);
                // Geocoder from streetMapPremiumPackage
                _geocoder = streetMapPremiumPackage.LocatorTask;
                _geocoder.LoadAsync();
            catch (Exception ex)
                // Handle any exception
                System.Windows.MessageBox.Show(ex.Message, "Error opening package");
                return;
 using a button like below (windows forms)
namespace WindowsFormsApp1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private async void button1_Click(object sender, EventArgs e)
            await Locator.MapViewModel.ConfigureStreetMapPremium();
MichaelBranscomb
Can you also share the contents of the csproj file?
SOTIRIOSTRIANTOS
<?xml version="1.0" encoding="utf-8"?>
<Project ToolsVersion="15.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
  <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
  <PropertyGroup>
    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
    <ProjectGuid>{399832F2-7852-4DC0-B948-4AB750F7E074}</ProjectGuid>
    <OutputType>Library</OutputType>
    <AppDesignerFolder>Properties</AppDesignerFolder>
    <RootNamespace>Locator</RootNamespace>
    <AssemblyName>Locator</AssemblyName>
    <TargetFrameworkVersion>v4.6.1</TargetFrameworkVersion>
    <FileAlignment>512</FileAlignment>
    <Deterministic>true</Deterministic>
    <NuGetPackageImportStamp>
    </NuGetPackageImportStamp>
  </PropertyGroup>
  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
    <DebugSymbols>true</DebugSymbols>
    <DebugType>full</DebugType>
    <Optimize>false</Optimize>
    <OutputPath>bin\Debug\</OutputPath>
    <DefineConstants>DEBUG;TRACE</DefineConstants>
    <ErrorReport>prompt</ErrorReport>
    <WarningLevel>4</WarningLevel>
  </PropertyGroup>
  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
    <DebugType>pdbonly</DebugType>
    <Optimize>true</Optimize>
    <OutputPath>bin\Release\</OutputPath>
    <DefineConstants>TRACE</DefineConstants>
  </PropertyGroup>
  <ItemGroup>
    <Reference Include="PresentationCore" />
    <Reference Include="PresentationFramework" />
    <Reference Include="System" />
    <Reference Include="System.Core" />
    <Reference Include="System.Device" />
    <Reference Include="System.Net.Http.WebRequest" />
    <Reference Include="System.Xaml" />
    <Reference Include="System.Xml.Linq" />
    <Reference Include="System.Data.DataSetExtensions" />
    <Reference Include="Microsoft.CSharp" />
    <Reference Include="System.Data" />
    <Reference Include="System.Net.Http" />
    <Reference Include="System.Xml" />
    <Reference Include="WindowsBase" />
  </ItemGroup>
  <ItemGroup>
    <Compile Include="MapViewModel.cs" />
    <Compile Include="Properties\AssemblyInfo.cs" />
  </ItemGroup>
  <ItemGroup>
    <PackageReference Include="Esri.ArcGISRuntime">
      <Version>100.11.2</Version>
    </PackageReference>
    <PackageReference Include="Esri.ArcGISRuntime.runtimes.win">
    </PackageReference>
  </ItemGroup>
  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
</Project>
MichaelBranscomb
A couple of options for resolving this:
