I cannot see the map
3354
04-14-2015 08:25 AM
ELIZABETH50
I installed the ArcGIS Runtime SDK for WPF and I can build and run the application successfully, but I cannot see the map after I ran it on the window.  Any suggestions?
MichaelBranscomb
Esri Frequent Contributor
First, if you are new to the product then you should download and install ArcGIS Runtime SDK for .NET (ArcGIS Runtime SDK for .Net | ArcGIS for Developers ).
Do you see anything on the MapView control? e.g. a gray background grid? an Esri logo?
Cheers
Mike
ELIZABETH50
Thx.
