I am getting a 400 bad request from getting the item from the portal on Xamarin Forms UWP
15281
12
06-28-2018 08:10 AM
PaulFarrow1
I already have code for Xamarin Forms iOS and Xamarin Forms Android that gets a config file from the ESRI portal and that works for both platforms.  I added the UWP component as we are now going to support UWP and I get a 400 bad request from the item.GetDataAsync() method.  I have already logged in and got a list of portal groups, I can select that group and the portal.createasync method appears to work but when I try to get the item with an id from the getdataasync() method that is when I get the 400 error.
When I put fiddler on the call I see the following error.
<?xml version="1.0" encoding="UTF-8"?>
<Error><Code>InvalidArgument</Code><Message>Only one auth mechanism allowed; only the X-Amz-Algorithm query parameter, Signature query string parameter or the Authorization header should be specified</Message><ArgumentName>Authorization</ArgumentName><ArgumentValue>Bearer XkcPcpODgq7bMLP3nLURAPrsXtM9gRbRcUaZf_igsXn5xn_5k0JC0TKuJBYkf2gUmvzeU9j7FE1PXYHR--Cr5hyKhf-cRkptCZp6VsTpXxPx6N3ZCXPKVRGoYVnPpPKVpZn71vMOCeuy_6Cn6J_Pxx2UQrwh5w31I0EGopXSPC5bKdLqvSKAEEs_69eDckTQ8Fl4CLGA2YaxfmmPxS5ZD4tKeLc6qUSvakHEEpv_awI1cA7N2FX1-sdpSPIa5BMG</ArgumentValue><RequestId>01BA2DD12883F913</RequestId><HostId>dvHaOQtMJgZzEOytj3oem4DkSFBLWN1mVgaZd39Fh4KTzVMOELkKGKtvG3ccb3g+dC5PnXekL98=</HostId></Error>
Ideas please?  Has any got this going on Xamarin Forms UWP.  I am using the 100.2.1 runtime.
Thanks in advance.
MatthewPierce
Hi Paul,
Not sure if you're still stuck on this, but I was able to find the handler in 100.2.1: Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler
You do not need to create a new instance, the EventHandler is right on the class itself. Hope that helps!
Matthew
PaulFarrow1
Hey Matthew
My bad I think I had some reference issues that made me think this was a problem.  Battled with it again this morning and I can confirm that I have it working also.
Thank you for your help there Matthew and ESRI.
Cheers
Paul
JenniferNery
Good news! This bug has been fixed by Microsoft. Please update your nuget package for `Microsoft.NETCore.UniversalWindowsPlatform` to 6.1.9.
