Get Azimuth value from point A to point B
8432
8
05-24-2019 01:19 AM
MohamadFathin
May i know how can i get a azimuth value between 2 points?
TedKowal
Honored Contributor
Calculating a bearing distance—Help | ArcGIS Desktop
How to Calculate Azimuth in Excel | It Still Works
Now if you can script in Excel this is a custom function I use for determining Azimuths..
I use it in excel like this... =Azimuth(cell with Latitude1, cell with Longitude1, cell with Latitude1, cell with Longitude2)
                                         eg.  =Azimuth(A1,B1,A2,B2)
Function Azimuth(lat1 As Single, lat2 As Single, lon1 As Single, lon2 As Single) As Single
Dim X1 As Single, X2 As Single, Y As Single, dX As Single, dY As Single
With Application.WorksheetFunction
    X1 = .Radians(lat1)
    X2 = .Radians(lat2)
    Y = .Radians(lon2 - lon1)
End With
    dX = Math.Cos(X1) * Math.Sin(X2) - Math.Sin(X1) * Math.Cos(X2) * Math.Cos(Y)
    dY = Math.Cos(X2) * Math.Sin(Y)
    Azimuth = .Degrees(.Atan2(dX, dY))
End With
End Function
Nicholas-Furness
Use the GeometryEngine.DistanceGeodetic method. The result, a GeodeticDistanceResult, includes the azimuths between the two points.
MohamadFathin
Hi
I try using the method for calculate to get the azimuth between 2 point, but i am not understand these two functions:
private readonly LinearUnit _metersUnit;
private readonly AngularUnit _degreesUnit;
below is the code i try to implement, sorry i am new to c#
private void CreatePoints()
// Create a red circle simple marker symbol
SimpleMarkerSymbol redCircleSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Circle, System.Drawing.Color.FromArgb(0xFF, 0xFF, 0x00, 0x00), 10);
MapPoint mapPoint1 = new MapPoint(-2.72, 56.065, SpatialReferences.Wgs84);
MapPoint mapPoint2 = new MapPoint(-2.69, 56.065, SpatialReferences.Wgs84);
// Create graphics and add them to graphics overlay
Graphic graphic = new Graphic(mapPoint1, redCircleSymbol);
_overlay.Graphics.Add(graphic);
graphic = new Graphic(mapPoint2, redCircleSymbol);
GeodeticDistanceResult distance = GeometryEngine.DistanceGeodetic(mapPoint1, mapPoint2, _metersUnit, _degreesUnit, GeodeticCurveType.Geodesic);
Nicholas-Furness
Hi Mohamad Fathin,
You could set them up something like this:
private readonly LinearUnit _metersUnit = LinearUnits.Meters;
private readonly AngularUnit _degreesUnit = AngularUnits.Degrees;
or just call DistanceGeodetic like this:
GeodeticDistanceResult distance = GeometryEngine.DistanceGeodetic(mapPoint1, mapPoint2, LinearUnits.Meters, AngularUnits.Degrees, GeodeticCurveType.Geodesic);
See LinearUnits and AngularUnits.
Hope that helps!
Nick.
MohamadFathin
HI Nicholas Furness
I get below error, did you know how to settle this issues?
System.InvalidOperationException
HResult=0x80131509
Message=Invalid id for creating a unit
Source=Esri.ArcGISRuntime
StackTrace:
at Esri.ArcGISRuntime.Geometry.Unit.FromUnitId(Int32 unitId)
at Esri.ArcGISRuntime.Geometry.LinearUnits.get_Meters()
at ArcGISControl.MainWindow..ctor() in C:\Users\mfathin.CSYSINT\Documents\Visual Studio 2017\Projects\ArcGISControl\ArcGISControl\MainWindow.xaml.cs:line 32
Inner Exception 1:
DllNotFoundException: Unable to load DLL 'RuntimeCoreNet.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
This my code:
graphic1 = new Graphic(mapPoint1, redCircleSymbol);
_overlay.Graphics.Add(graphic1);
graphic2 = new Graphic(mapPoint2, redCircleSymbol);
_overlay.Graphics.Add(graphic2);
//CreateLinePoint();
textBox.Text = string.Format("Distance:{0} | Azimuth:{1}", _metersUnit.UnitType.ToString(), _degreesUnit.UnitType.ToString());
NathanCastle1
I tried the code locally and found the following worked for the basic use case of finding the azimuth values:
MessageBox.Show($"Distance:{distance.Distance} | Azimuth1:{distance.Azimuth1} | Azimuth2:{distance.Azimuth2}");
That is essentially what you had, and based on the error message you shared (Unable to load DLL 'RuntimeCoreNet.dll': The specified module could not be found), this looks like a deployment issue.
Did you use Nuget to reference the ArcGIS Runtime SDK? Have you tried cleaning, clearing the bin/ and obj/ folders, and then rebuilding?
MohamadFathin
Hi ,
Thank you for your answer. I manage to get the azimuth from point 1 to point 2 and vice versa. One thing that i want to know. The azimuth start from 0 to 180 for clock wise and -0 to -180 for anti-clockwise. After the 180 on clockwise the degree become negative that start with -180 until -0. How can i make azimuth from 0 to 360 ?
Nicholas-Furness
If the value is < 0, add 360. -179 becomes 181. -10 becomes 350, etc.
