Filter display of FeatureTable records
4667
04-30-2015 05:42 PM
JasonMann
Is there a simple way to filter the display of local offline FeatureTable records?  The ServiceFeatureTable contains a Where clause to add an expression to filter the records that are displayed on the map when a layer is added, but the FeatureTable does not appear to have this functionality.  I only want to display features that are not set to "Completed" in the attribute table field.
AnttiKajanus1
You can use FeatureLayer.DefinitionExpression Property to define what is visible.
JasonMann
Thanks for your reply.  That is exactly what I needed and I can't believe that I overlooked that property.
