Feature Reduction clear graphics not working
2159
8
03-25-2025 04:59 AM
Labels (4)
LucaCastenetto
I'm using the Feature Reduction to display clusters of graphics inside a GraphicOverlay. The clustering works fine but if I clear the graphics inside the overlay the clusters are still drawn on the map.
The clear is done using
_overlay.Graphics.Clear();
If I try to identify the elements it correctly returns no results because there isn't any graphic.
I'm using SDK version 200.6 with .NET 9.
pnarkhede
Esri Alum
Hi Luca,
Thank you for following up and for your patience. I checked with our internal team who worked on this bug, and I can confirm the issue is resolved in the upcoming 200.8.1 release. We recommend updating to this version once it's available. Please let us know if you experience any further issues after upgrading.
Thanks again for your feedback and persistence!
pnarkhede
Esri Alum
Hi @LucaCastenetto ,
Thank you for reporting this issue. We’ve confirmed the behavior where clusters persist after clearing GraphicsOverlay.Graphics. This appears to be a bug in the SDK rather than a configuration issue. This has been confirmed as a core issue by the development team, and logged it as a bug.
For now, you'll need to wait for the fix to be implemented in an upcoming release. Thanks again for reporting it!
LucaCastenetto
Hi @pnarkhede ,
Thank you for the update! Do you have an estimated release date for the fix?
pnarkhede
Esri Alum
We are close to releasing version 200.7 of the ArcGIS SDK, which is scheduled for Q2 2025. The fix for the issue you reported is expected to be included in version 200.8, which is planned for release in Q3 2025. Thank you for your patience!
LucaCastenetto
Hi @pnarkhede ,
I’ve updated to version 200.8, but I’m still encountering the same issue. I also couldn’t find any mention of this bug in the release notes for this version.
At the moment, this is blocking our use of the affected functionality. Could you please confirm the expected release version that will include the fix?
Thank you
Luca
LucaCastenetto
Hi @pnarkhede ,
Following up again — it’s been a while since the last update, and we’re still blocked by this issue. Could you please confirm the release version where the fix is planned, or share any workaround we can use in the meantime?
This is impacting our progress, so an update would be greatly appreciated.
Luca
pnarkhede
Esri Alum
Hi Luca,
LucaCastenetto
Hi @pnarkhede ,
Thank you for the response but I don't see the version 200.8.1 released yet. Could you tell me when it will be available?
Luca
pnarkhede
Esri Alum
Hi Luca,
I don’t have a specific time frame available at the moment. The release date for 200.8.1 hasn’t been confirmed in the updates I have. However, based on the recent development activity and fixes being logged, the version is actively being worked on and should be available soon.
