Failure loading MapView after upgrade to 200.7,
1830
04-15-2025 12:59 PM
Labels (3)
JoeHershman
I just upgraded my app to use 200.7 and now when I try to load MapView it crashes.  I am looking through getting started, don't see anything I need to change.  I have been using net9.0 for a while on the 200.6 release
System.InvalidOperationException: Unable to convert Esri.ArcGISRuntime.Maui.MapView to UIKit.UIView
   at Microsoft.Maui.Platform.ElementExtensions.ToPlatform(IElement view)
   at Microsoft.Maui.ElementHandlerExtensions.ToPlatform(IElementHandler elementHandler)
   at Microsoft.Maui.ViewHandlerExtensions.GetDesiredSizeFromHandler(IViewHandler viewHandler, Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Handlers.ViewHandler`2[[Esri.ArcGISRuntime.Maui.IMapView, Esri.ArcGISRuntime.Maui, Version=200.7.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86],[Esri.ArcGISRuntime.UI.Controls.MapView, Esri.ArcGISRuntime.iOS, Version=200.7.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86]].GetDesiredSize(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.LayoutExtensions.ComputeDesiredSize(IView view, Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.VisualElement.MeasureOverride(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.VisualElement.Microsoft.Maui.IView.Measure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.GridLayoutManager.GridStructure.MeasureCell(Cell cell, Double width, Double height)
   at Microsoft.Maui.Layouts.GridLayoutManager.GridStructure.FirstMeasurePass()
   at Microsoft.Maui.Layouts.GridLayoutManager.GridStructure.MeasureCells()
   at Microsoft.Maui.Layouts.GridLayoutManager.GridStructure..ctor(IGridLayout grid, Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.GridLayoutManager.Measure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.Layout.CrossPlatformMeasure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Platform.MauiView.CrossPlatformMeasure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Platform.MauiView.SizeThatFits(CGSize size)
   at Microsoft.Maui.Handlers.ViewHandler`2[[Microsoft.Maui.ILayout, Microsoft.Maui, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null],[Microsoft.Maui.Platform.LayoutView, Microsoft.Maui, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null]].GetDesiredSize(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.LayoutExtensions.MeasureContent(IContentView contentView, Thickness inset, Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.LayoutExtensions.MeasureContent(IContentView contentView, Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.TemplatedView.Microsoft.Maui.ICrossPlatformLayout.CrossPlatformMeasure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Handlers.ViewHandler`2[[Microsoft.Maui.IContentView, Microsoft.Maui, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null],[Microsoft.Maui.Platform.ContentView, Microsoft.Maui, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null]].GetDesiredSize(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.TemplatedView.MeasureOverride(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Controls.Compatibility.Layout.Microsoft.Maui.IView.Measure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Layouts.GridLayoutManager.GridStructure.SecondMeasurePass()
   at Microsoft.Maui.Controls.ContentPage.Microsoft.Maui.ICrossPlatformLayout.CrossPlatformMeasure(Double widthConstraint, Double heightConstraint)
   at Microsoft.Maui.Platform.MauiView.LayoutSubviews()
   at Microsoft.Maui.Platform.ContentView.LayoutSubviews()
   at Microsoft.Maui.Platform.ContentView.__Registrar_Callbacks__.callback_844_Microsoft_Maui_Platform_ContentView_LayoutSubviews(IntPtr pobj, IntPtr sel, IntPtr* exception_gchandle)
-Joe
dotMorten_esri
Esri Notable Contributor
Sounds like a restore/deployment or target framework issue. Is your .NET MAUI up to date? Try deleting bin/obj folders and restart visual studio, or perform a manual "dotnet restore" from command line.
JoeHershman
Doing a little more debugging and I get this before the error listed above
System.DllNotFoundException: __Internal
   at RuntimeCoreNet.GeneratedWrappers.CoreGeoView.get_ImageOverlays()
   at Esri.ArcGISRuntime.UI.Controls.GeoView.Initialize(CoreGeoView geoView)
   at Esri.ArcGISRuntime.UI.Controls.GeoView..ctor(CoreGeoView geoView)
   at Esri.ArcGISRuntime.UI.Controls.MapView..ctor()
   at Esri.ArcGISRuntime.Maui.Handlers.MapViewHandler.CreatePlatformView()
-Joe
dotMorten_esri
JoeHershman
Ran a clean and deleted bin/obj folders.  Deleted the app from device also.
Everything is now running with 200.7.  Also, have the new barcode scan working with FeatureForm in the 200.7 toolkit
-Joe
