Export Map as emf file
1216
09-14-2023 11:25 AM
Labels (2)
sylvainc
I just started to use the .Net SDK and I am looking for exporting my map/viewport into a vector image as I used to do in the ArcGIS software. There is no tutorial on that topic in the documentation. Is there a good example somewhere else?
Thank you
Sylvain
sylvainc
I have written the following code but the resolution is not good enough. I don't see how I can indicate these settings:
await WaitForRenderCompleteAsync(MyMapView);
// Export the image from the map view.
RuntimeImage image = await MyMapView.ExportImageAsync();
Stream fileStream = await image.GetEncodedBufferAsync();
string path = Path.Combine("C:\\Users\\xxx\\Documents", "testesri.emf");
using (FileStream outputFileStream = new FileStream(path, FileMode.CreateNew))
await fileStream.CopyToAsync(outputFileStream);
Any ideas?
