Exception in Runtime 100.3 when the map is activated after a long time.
7503
13
09-11-2018 02:35 AM
Jean-ChristopheBertolini
Just for information to the developers if this can help then, I don't know where to post:
Esri.ArcGISRuntime.ArcGISRuntimeException
  HResult=0x80131500
  Message=DirectX failure CreateQuery code = 0x887a0005:
c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(203) : error : Exception caught in RT_GeoView_pulse
  Source=Esri.ArcGISRuntime
  Arborescence des appels de procédure :
   à Esri.ArcGISRuntime.ArcGISException.HandleCoreError(CoreError error, Boolean throwException)
   à RuntimeCoreNet.GeneratedWrappers.Interop.CheckError(IntPtr errorHandle, Boolean throwOnFailure, GCHandle wrapperHandle)
   à RuntimeCoreNet.GeneratedWrappers.CoreGeoView.Pulse()
   à Esri.ArcGISRuntime.UI.Controls.GeoView.Esri.ArcGISRuntime.Internal.IDxSurfaceSource.Pulse()
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.CompositionTarget_Rendering(Object sender, EventArgs e)
   à System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType)
   à System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
   à Esri.ArcGISRuntime.Internal.RenderingWeakEventManager.OnCompositeTargetRendering(Object sender, EventArgs e)
   à System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   à System.Windows.Media.MediaContext.AnimatedRenderMessageHandler(Object resizedCompositionTarget)
   à System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   à System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   à System.Windows.Threading.DispatcherOperation.InvokeImpl()
   à System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   à MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   à MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   à System.Windows.Threading.DispatcherOperation.Invoke()
   à System.Windows.Threading.Dispatcher.ProcessQueue()
   à System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   à System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   à MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   à System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   à System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.SurfaceBackgroundUiWorker(Object arg)
   à System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   à System.Threading.ThreadHelper.ThreadStart(Object obj)
BradyHoukom
This is exactly what happened. The application was at the peak of memory usage, but only the 2GB default not the full 4GB that should be allocated due to a flag not being set for our .NET application to allow large address.
I migrated on the 100.6 runtime and the exception is still present in this version. Are you planning to do something to avoid crashing the application?
Regards,
  HResult=0x80131500
  Message=Internal error exception. error creating vertex buffer!:
c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(1296) : error : Exception caught in RT_GeoView_pulse
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.<AttachRenderingEvent>b__29_0(HostedSurfaceElement instance, Object source, EventArgs args)
   à Esri.ArcGISRuntime.Internal.WeakEventListener`3.OnEvent(TSource source, TEventArgs eventArgs)
MathieuLemay1
Same issue with 100.8
Application: XXXXX.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: Esri.ArcGISRuntime.ArcGISRuntimeException
at Esri.ArcGISRuntime.ArcGISException.HandleCoreError(RuntimeCoreNet.GeneratedWrappers.CoreError, Boolean)
at RuntimeCoreNet.GeneratedWrappers.Interop.CheckError(IntPtr, Boolean, System.Runtime.InteropServices.GCHandle)
at RuntimeCoreNet.GeneratedWrappers.CoreGeoView.Pulse()
at Esri.ArcGISRuntime.UI.Controls.GeoView.Esri.ArcGISRuntime.Internal.IDxSurfaceSource.Pulse()
at Esri.ArcGISRuntime.Internal.HostedSurfaceElement.CompositionTarget_Rendering(System.Object, System.EventArgs)
at Esri.ArcGISRuntime.Internal.HostedSurfaceElement.<AttachRenderingEvent>b__29_0(Esri.ArcGISRuntime.Internal.HostedSurfaceElement, System.Object, System.EventArgs)
at Esri.ArcGISRuntime.Internal.WeakEventListener`3[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].OnEvent(System.__Canon, System.__Canon)
dotMorten_esri
Esri Notable Contributor
Thank you for following up. We still haven't been able to reproduce this issue and lack a set of repro steps to reproduce this issue, so we can better understand why this might happen.
