esritoolkit:BasemapGallery - AvailableBasemaps customization does not work
4489
10
02-02-2023 06:18 AM
ViktorSafar
I have got a WPF MVVM app where I have a MapView, and the BasemapGallery from the toolkit:
        <esri:MapView
            x:Name="MainMapView"
            Map="{Binding Map}"
        <esritoolkit:BasemapGallery
            x:Name="BasemapGallery"
            GeoModel="{Binding ElementName=MainMapView, Path=Map}"
            AvailableBasemaps="{Binding AvailableBasemaps}"/>
The Map property on the VM:
private Map _map;
public Map Map
	get { return _map; }
	set { SetProperty(ref _map, value); }
// initialized in VM constructor
Map = new Map
	InitialViewpoint = new Viewpoint(new MapPoint(X, Y, spatialReference: SpatialReference.Create(3857)), 130617),
	Basemap = new Basemap(BasemapStyle.ArcGISTopographic)
Changing the mapview's base map from the gallery works fine. The gallery loads base maps from AGOL which is something I would like to override. The app will be on an offline device so I have some map packages locally but I am currently testing with a VectorTileServer base map:
var vectorTiledLayer = new ArcGISVectorTiledLayer(new Uri("https://server/arcgis/rest/services/MyService/VectorTileServer"));
var newBaseMap = new Basemap(vectorTiledLayer)
var item = await BasemapGalleryItem.CreateAsync(newBaseMap);
AvailableBasemaps = new List<BasemapGalleryItem>();
AvailableBasemaps.Add(item);
// where AvailableBasemaps is:
private IList<BasemapGalleryItem> _availableBasemaps;
public IList<BasemapGalleryItem> AvailableBasemaps
	get { return _availableBasemaps; }
	set { SetProperty(ref _availableBasemaps, value); }
The gallery is still showing the AGOL base maps, and not at all my custom base map.
What am I doing wrong?
Esri.ArcGISRuntime.WPF v100.15.0
Esri.ArcGISRuntime.Toolkit v100.15.0
ViktorSafar
If anyone's using Prism, there is a dead simple way to make your own gallery
XAML:
<UserControl x:Class="MapGallery.MapGalleryUC"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:prism="http://prismlibrary.com/"
             prism:ViewModelLocator.AutoWireViewModel="True">
    <ListView
        ItemsSource="{Binding AvailableMaps}"
        SelectedValue="{Binding SelectedMap}"
        <ListView.ItemTemplate>
            <DataTemplate>
                <WrapPanel>
                    <Image Source="{Binding Thumbnail}" Height="100" Width="100" />
                    <Label Content="{Binding Basemap.Name}" VerticalContentAlignment="Center"/>
                </WrapPanel>
            </DataTemplate>
        </ListView.ItemTemplate>
    </ListView>
</UserControl>
VM:
internal class MapGalleryVM : BindableBase
	private readonly IEventAggregator _eventAggregator;
	public MapGalleryVM(IEventAggregator eventAggregator)
		_eventAggregator = eventAggregator;
		_eventAggregator.GetEvent<BasemapsLoadedEvent>().Subscribe(HandleBasemapsLoadedEvent);
	private void HandleBasemapsLoadedEvent(List<AppBasemap> appMaps)
		var results = appMaps.Select(x => new MapGalleryModel()
			Basemap = x.Basemap,
			Thumbnail = new BitmapImage(new System.Uri(Path.Combine(System.AppDomain.CurrentDomain.BaseDirectory, x.MapFileConfig.Thumbnail)))
		_ = Application.Current.Dispatcher.BeginInvoke(() =>
			AvailableMaps = new ObservableCollection<MapGalleryModel>(results);
	private ObservableCollection<MapGalleryModel> _availableMaps;
	public ObservableCollection<MapGalleryModel> AvailableMaps
		get { return _availableMaps; }
		set { SetProperty(ref _availableMaps, value); }
	private MapGalleryModel _selectedMap;
	public MapGalleryModel SelectedMap
		get { return _selectedMap; }
		set
			if (value != SelectedMap)
				SetProperty(ref _selectedMap, value);
				_eventAggregator.GetEvent<BasemapChangedEvent>().Publish(value.Basemap);
The events
internal class BasemapChangedEvent : PubSubEvent<Basemap>
internal class BasemapsLoadedEvent: PubSubEvent<List<AppBasemap>>
public class AppBasemap
	public Basemap Basemap { get; set; }
	public MapFileConfig MapFileConfig { get; set; }
where MapFileConfig is just a holder for paths to the maps and thumbnails.
And wherever you handle your Map:
internal class MainMapVM : BindableBase
	public MainMapVM(IEventAggregator eventAggregator)
		_eventAggregator.GetEvent<BasemapChangedEvent>().Subscribe(HandleBasemapChangedEvent);
		LoadBasemaps().Await();
	private void HandleBasemapChangedEvent(Basemap obj)
		Map.Basemap = obj;
	private async Task LoadBasemaps()
		var appBasemaps = await _layerProvider.GetAppBasemaps(_isOnline);
		Map.Basemap = appBasemaps.First().Basemap;
		_eventAggregator.GetEvent<BasemapsLoadedEvent>().Publish(appBasemaps);
	private Map _map;
	public Map Map
