Esri.ArcgisRuntime.Forms.UWP Map FailedToLoad
2136
11-20-2019 02:03 PM
JérômeDuckers
I try to load a map with Esri.ArcgisRuntime.Forms.
With an IOS project I encountered no problem, but with a UWP project I receive a Load Map Status as  "FailedToLoad".
My Question is, is there another property I can call to know what's going wrong ?
When I try with Mapserver found in internet, the map is loading, but with my map (and my spatialreference 31370), I always receive "FailedToLoad".
When I ask the status directly on the layer I receive with LoadError.Message => One or more errors occurred. (An error occurred while sending the request.)
Jérôme.
JérômeDuckers
Hi Community,
Finally I solve my problem.
The error was not very easy to determine, because the information was not relevant enough.
Indeed with my code, I could consume map providing by AGOL, or another provider, but with my network it was impossible.
The solution is to check in the “appxmanifest”  Privat networks (Client & Server).
I had already checked “Internet (Client)” that the reason why my map was working with another network.
Jérôme.
JérômeDuckers
Hi Community,
Jérôme.
dotMorten_esri
Esri Notable Contributor
Yes this is a security setting for UWP apps: You have to explicitly opt in to allow it to access services on the intranet, or webrequests will fail.
JérômeDuckers
For a permission, I was waiting an exception or something like that.
The error wasn't clear enough, I think
dotMorten_esri
Fair enough. We merely forward the web request error that's returned from UWP - There's unfortunately not a specific error that tells you it was the manifest blocking it.
