Error initializing the ArcGISRuntimeEnvironment environment. The ArcGISRuntime deployment folder could not be found. Verify that a folder named "arcgisruntime100.1"
6308
10
08-24-2017 07:03 AM
ManelKEDDAR
I have a problem when i try to excute my applications the error is (
Error Error initializing the ArcGISRuntimeEnvironment environment. The ArcGISRuntime deployment folder could not be found. Verify that a folder named "arcgisruntime100.1" is in the same folder as your application's executable file, or set ArcGISRuntimeEnvironment.InstallPath to reference another location. The deployment folder must contain subfolders that match the processing architecture of your application. SceneLayer C: \ Users \ user \ Documents \ Visual Studio 2015 \ Exercise \ SceneLayerSol \ SceneLayer \ MainWindow.xaml )
The fact is that i verified and the folder  "arcgisruntime100.1" does existe with my .exe file but i didn't understant how to set ArcGISRuntimeEnvironment.InstallPath to reference another location? can you tell me how to do that ? thanks
VanyaIvanov
worked. Thank you
