Envelope causes access violation crash
6005
6
10-15-2014 09:14 AM
MarkCederholm
I have a class for flashing geometry (attached) which worked just fine in the beta.  In the release, however, the app crashes with an access violation if the geometry is an envelope.  If I build a polygon from the envelope and use that instead, the error goes away.  Weird, huh?  Any idea why this might be happening?
JenniferNery
Hi Mark,
Thank you. This is very helpful. I can reproduce the issue consistently even without your helper class. GraphicsLayer with labeling enabled crashes with AccessViolationException when it contains an Envelope geometry. I have logged an issue and we'll try to get it fixed in future releases.
JenniferNery
Hi Mark,
Do you mind sharing the sample code for flashing geometry that uses Envelope? I can't seem to see attachment.
MarkCederholm
I can see it on my post: clsGraphicHelper.cs.zip 1.7K
JenniferNery
Sorry, I was looking from a expanded view of your post from the main landing page: ArcGIS Runtime SDK for .NET I didn't realize attachments are only visible from within the message.
Anyway, I used your helper class with this very simple sample. I commented out the workaround of replacing g with PolygonBuilder but I'm not able to reproduce the issue.  It seems to work without AccessViolationException. I ran the sample against the final released version 10.2.4.748
             xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013">
    <Grid x:Name="LayoutRoot"
          Background="White">
        <esri:MapView x:Name="MyMapView">
        <esri:Map >
            <esri:ArcGISTiledMapServiceLayer ServiceUri="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" />
                <esri:GraphicsLayer ID="MyLayer" />
            </esri:Map>
        </esri:MapView>
        <StackPanel Orientation="Horizontal"
                    VerticalAlignment="Top"
                    HorizontalAlignment="Center">
            <Button Content="Flash"
                    Click="Button_Click" />
        </StackPanel>
    </Grid
        private async void Button_Click(object sender, RoutedEventArgs e)
            string message = null;
            try
                var geometry = await MyMapView.Editor.RequestShapeAsync(DrawShape.Envelope);
                var graphic = new Graphic() { Geometry = geometry, Symbol = new SimpleFillSymbol() };
                var layer = MyMapView.Map.Layers["MyLayer"] as GraphicsLayer;
                layer.Graphics.Add(graphic);
                clsGraphicHelper.FlashGeometry(MyMapView, geometry, geometry.Extent.GetCenter());
            catch (TaskCanceledException)
            catch (Exception ex)
                message = ex.Message;
            if (!string.IsNullOrWhiteSpace(message))
                MessageBox.Show(message);
MarkCederholm
The problem is using FlashGeometry with an Envelope on a graphics layer with a label class:
      public MainWindow()
         InitializeComponent();
         TextSymbol txtSym = new TextSymbol();
         AttributeLabelClass lc = new AttributeLabelClass();
         lc.Symbol = new TextSymbol();
         lc.TextExpression = "[SomeFieldName]";
         layer.Labeling.LabelClasses.Add(lc);
         layer.Labeling.IsEnabled = true;
         var geometry = await MyMapView.Editor.RequestShapeAsync(DrawShape.Rectangle);
         //geometry = geometry.Extent; // Uncomment this line to make app crash
JenniferNery
Hi Mark,
MarkCederholm
I see this is fixed at 10.2.5.  Thanks.
